Question about Dell Studio Computers & Internet
Ac power adapter type cannot determined - Studio Dell Computers & Internet
Pyrhyc
  • 2028 Answers
SOURCE: Dell Inspirion 1526 Laptop Battery is not charging
Sound like the battery. Take the battery out and there should be a power meter on it, press it, if there are three lights that flash, the battery is shot. Not all batteries will flash if they are worn out, but they are supposed to. Try a new battery, I believe this will coorect the issue.
Posted on Jun 21, 2008
  • 3 Answers
SOURCE: Dell Inspiron 1501 AC Adapter error message
The Dell 1501 ac adapter (possibly other Dell’s as well) has been known to be problematic because of its lack of a plug to jack secure fit. You will notice that the plug can all too easily be pulled from the jack, as opposed to other systems where the plug fits more securely onto the jack. The plug and jack combination is poorly designed so that over time, the plug will come unseated depending on how much movement the machine is subjected to. This will result in power error messages or outright power-up failure. So before assuming you have a faulty adapter, make sure that it is not just a loose plug that is causing the problem. If you look inside the jack, you will notice that there is a 3mm region of non-conductive material nearest the surface of the jack. Use a strip of standard electrical tape 3mm wide and long enough and wrap it around the base of the plug (you may need more than one layer of tape to get a good fit). I have used this method to secure my plug and it has served me well. If the tape comes undone over time, just simply replace it. A more “elegant” method would be to use an “O” ring of the appropriate size (about 6mm) around the base of the plug in lieu of the tape.
Posted on Dec 25, 2008
  • 3940 Answers
SOURCE: my computer does not reconize my ac adapter
If the BIOS cannot ID the charger, the battery will not be charged. Cause: There is a fine wire in the middle of the canon plug to the computer, that sends an ID of the adapter to the BIOS. If that pin is bent or broken, then the system will be powered, but the battery charger is disabled. If another AC adapter for a Dell D-series is available, see if the issue goes away with diferent adapter. If no adapter is available, they are <$50 on Ebay. If you replace the AC adapter, and the issue still occurs, then you'll need to replace the motherboard.
Posted on Jun 14, 2009
lserni
  • 466 Answers
SOURCE: the ac power adapter wattage and type cannot be determined .
There are at least four possible causes for this error - (error 3600-0749, right?).
First one: the adapter is faulty. You would need a tester to determine whether the adapter is indeed supplying power. Dell will send you a replacement adapter if the warranty is still good, or you can find one online (model PA-19 PN402, 230W).
Second: one of the DC jack solder points on the motherboard cracked. You may see the error disappear by "wiggling" delicately the jack in the notebook. You either need to call Dell tech support and have the MB replaced for free (if under warranty), at cost - in excess of EUR 400 - or the jack may be resoldered, which will void the warranty and requires experience in disassembling and reassembling the laptop.
Third: motherboard is otherwise damaged (voltage regulators, buffers, and so on). Diagnostics must be performed by a Dell technician; replacement policy as above.
Fourth: you may have problems with the BIOS (if it is a brand new unit), solvable by upgrading - Dell will suggest this avenue first if you call tech support, anyway, so check you've got up-to-date BIOS and drivers.
Posted on Dec 02, 2009
romeetb
  • 66 Answers
SOURCE: My battery won't charge on my laptop. It gives me
hi there,
i happen to see that a lot.usually its a fault with the power adapter or you are probably using an alternative ( universal ) power adapter. please check and let me know. you could take it to a computer store near you and try using a new dell adapter to rule that out?
Posted on Feb 04, 2010
Cannot turn on my laptop only the start button light turns on but no screen display and a few noises help
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 15, 2011 | Acer Aspire 5500 5570-2609 Laptop
My laptop wont charge and it says that the ac adapter type cannot be determined
this sounds like either your ac adapter is faulty, or the power supply module inside the laptop has an issue.
We ideally want the external power adapter to have the faul, as that can be replaced. Do you have a friend with a Dell laptop, or one at work. Basically use a different power adapter. If that works then you need to buy a new power adapter.
If you get the same problem with a different power adapter, then it is more serious and you will need to send you laptop off for repair.
Good Luck!
Feb 24, 2010 | Dell Inspiron 1545 Notebook
The ac power adapter type cannot be determined,your system will operate slower and the bettery will not charge. please connect a dell 65w AC adapter or Higher for best system operation.
Dell power supplies use 3 wires. One detects the power supply. If you are using a Dell supply then that wire is broken inside the cord or at the connection. If this a universal power supply it only has 2 wires.
Nov 14, 2009 | Televison & Video
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
Nov 11, 2009 | Dell Inspiron 1521 Laptop
My Dell precision M90 will not turn on all the way it acts like its going to boot up and then comes to a screen that either says the battery can not support the system press F1 to shutdown (when it is not...
Seems that either the battery or the power adapter is defective. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 27, 2009 | Dell Precision M90 Notebook
Computers & Internet Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
