Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Picture in blue
My Zenity E44W46LCD tv is suddenly showing the picture in shades of BLUE. What causes this and can it be repaired?
  • Anonymous Feb 10, 2009
    Same problem here. It is just a piece of ****.
  • Tamicasnan Feb 28, 2009
    We have a Sony VPL-HS3 projector and the picture is blue, we rang Sony when it first happened and were told to take it to their service reps, unfortunately they are useless, and nothing was done. The problem has progressively gotten worse now we have just a circle in the middle of the screen that is normal colour. Any suggestions as to what could be the problem?
This is likely a bad light engine. or so I'm told by the LG electronics. The cost of the part can be as much as you paid for the set itself. Call customer service and let them know of your problem and then ask to escalate the issue. LG electronics, although not admitting fault, tried to find a service rep but eventually bought back my set at a pro-rated amount. Overall, I was very satisfied with their support. Best advice I can give you is to not buy a rear projection set again, LCD or DLP. Lamps are expensive and design is unreliable. LCD flat screen is your best option, in my opinion.
Posted on Aug 29, 2007
SOURCE:
Image is showing with yellow & red shades
Ur convergence is dead.Must know how to solders?Replaced convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com to buy a convergence kit.Shop will cost u $300 for parts and labors.
Jan 16, 2010 | Hitachi 61UWX10B 61" Rear Projection...
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Kp-51ws510 picture issues
Bob, remove the front speaker panel and you will see a small access panel remove that also and you will see a small block with 6 dials on it. three on top and three on the bottom. Look closely at the dials and you will see focus for 3 of the dials and Screen for the other 3. The dials marked screen control the drive amount for each tube and are laid out like the tubes green dial in the middle and blue dial on the same side as the blue tube. try turning the blue tube down a little. If that deosnt help you will no doubt need a new blue tube, which is a fairly common problem with that model Sony. If you require more assistance please let me know.
Aug 08, 2008 | Sony KP-51WS510 51" Rear Projection...
Zenith E44W46 Audio works - intermittant picture
i hava a Zenith Model # E44W46LCD telivision. There is a light blue line about an inch or 2 wide running across the bottom of the screen. The TV is about 4 years old. It doesn't get a lot of play probably less than 10 hours a week. can you help me
Jul 18, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith 44" LCD TV
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Jul 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
BRIGTHNESS TO LOW
Light in wrong, however I wouldn't waste the money on this unit. Light engine will fail in 3 to 4 years and show a yellow spot at first.
(ie past post)
TV Tech
Jun 28, 2008 | Zenith E44W46LCD 44" Rear Projection...
Green picture
I have the same problem, the service people indicated this a manufacturer problem, they are not calling it a recall, but requires up graded parts which could take 30 days or more to receive. He said if they do not receive the parts in 30 days they might replace the TV. My TV is a Samsung DLP 61 inch
Oct 29, 2007 | Samsung DLP HL-P5663W 56" TV
Limited blue
your tv has a fault in the matrix board the blue driver volt to the screen is missing or some dried up soldering at a pin should be seen by qualified , but sereen is ok , regards please don't forget to rate thx
Apr 28, 2007 | Toshiba TP43H60 43" Television
Blue screen
you have a bad blue picture tube sony dos not make it anymoore , so you will have to have it rebuilt.
Apr 02, 2007 | Sony KP-57HW40 57" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
