Question about Radio Communications
Weide watch wh-903 instruction manual - Radio Communications
Weide wh1103 watch.hands stopped working.function buttons work ok.battery powered.hands move when turning winder button.
The Weide watches use springs for their electrical connectivity and I've found that they don't work very well. I had the same problem and after tinkering with all of the connections I came to the conclusion that they were built to not have the battery replaced.
Nov 01, 2017 | Watches
Weide wh1103 watch hands stopped working.other functions still ok.
1. did you check the battery? some analog-digital watches have two batteries. one for analog and the other for digital.
if so, try to replace one of the battery.
2. maybe your watch need to clean the internal mechanism. bring it to service center.
How do i set the day ? Mine is stuck on sun.
I would try removing the battery for 10 minutes reinstall the battery if it doesn't help there's a problem with the circuitry.
Hope it helps thank you.
Jun 10, 2015 | Novelty 30M Waterproof Analog & Digital...
My iphone 4s can not find my 903
Once you make your iphone discoverable, then put the Plantronics 903 headset into pairing mode by pressing the power button until it flashes red and blue. If it's not flashing red and blue, it's not in the pairing mode. Below is a link for the user guide which has the pairing instructions:
Plantronics BackBeat 903 Pairing Instructions
Good luck from Headsets Direct!
Nov 25, 2011 | Plantronics Backbeat 903 Bluetooth...
I am looking for instruction manual for Weide sports watch WH902
Does exist a function to beep hour a hour in model Weide WH2309?
free-shipping-watch-fashion-weide-sports-watches-wh-2309-with-quartz-led-watch-for-watches-men-aq2i4dbsyqjd0wgvev1j31bb-4-0.jpg
Nov 10, 2011 | Watches
Unable to conenct to laptop
Performing a system reset might take care of the problem. Reset instructions: Plug in the AC charger and hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Below is a link to the Backbeat 903 User's Guide for more information.
Plantronics Backbeat 903 User's Guide
Aug 02, 2011 | Plantronics Backbeat 903 Bluetooth...
MPlantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset red light flashing problems
The red flashing indicates a low (or check) battery. The instructions on page 4 in the link below for the Plantronics Backbeat 903/906 will show you how to charge it up. On page 8 you'll see how to power down and then up the headset to reset it.
Plantronics Backbeat 903/906 User's Guide
I cant sink with my iphone 4?
Once you make your iPhone discoverable, then put the Plantronics Backbeat 903 into pairing mode. With the headphones powered off, press and hold the Power / Pairing button until the LED Indicator flashes blue and red. Here is the link below for the Backbeat 903 user guide that has the pairing instructions as well.
Jul 26, 2011 | Plantronics Backbeat 903 Bluetooth...
I am not able to connect the headset and my BB
Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove the battery for a few seconds, then replace the battery and turn it back on again. If this does not resolve the issue, delete any pairing information for your BackBeat 903 headset and pair it again with your phone, carefully following the instructions on the link below for the Plantronics BackBeat 903.
Plantronics BackBeat 903 User's Guide
Mar 12, 2011 | Plantronics Backbeat 903 Bluetooth...
BACKBEAT 903 manual , i just got a bluetooth but it came with no manual and i want to know how to pair it to my cell phone
You can download the complete instruction manual in PDF format by clicking this link.
For more details, features and specifications, click here.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 01, 2010 | Plantronics Backbeat 903 Bluetooth...
Radio Communications Logo
234 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
