Question about Garden
Frazer rototiller convert frazer tiller to electric start
3 Suggested Answers
SOURCE: need specs.for Honda rototiller motor
The cam to crankshaft.... the plastic gear has a dot that you can see. mark the tooth with a sharpie so you can see it visible. its a cicle on the cam gear. on the crankshaft the cylinder needs to be at top dead center so when you put it back in all the way to the top. on the gear there is a notch that you line up the tooth on the cam to the two on the crankshaft. Its easier if you take the flywheel off to put it together. Hope I made sense
Posted on Aug 30, 2009
SOURCE: sears rear tine rototiller 32-29978 manual
Here is a link to a JC Penneys tiller that uses the same Briggs&Stratton engine 190402-1835-02 as my Sears 32-29978 8HP tiller.
http://dl.owneriq.net/a/af17c4af-5fe8-2b94-0155-02ad54e688e6.pdf
Posted on Mar 09, 2013
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
Earthquake rototiller won't disengage
the tensioner is to tight and belt stays engaged loosen the tension below the handle
Apr 04, 2014 | Earthquake 6015V Rear Tine Rototiller
What kind of spark plugs do i need
Try this site: http://www.lawnsite.com/showthread.php?t=214090
It has blogs about this type of old tiller.
Aug 04, 2012 | Atlas Translator Atlas Rototiller Worm...
How do you start the Huskee Rototiller 190CC? My
Yes, the engine is identical to the ones used on several lawnmowers and the safety bar must be held in against the handle to enable it to start. Releasing it while running will kill the engine.
Apr 11, 2011 | Mtd Products Yard Machines 158CC Tiller
Have this rototiller without a manual and need to know about fuel
the mixture is usually on the machine somewhere--if not go the honda website and look up info for that model
May 08, 2010 | Honda 25cc 4-cycle Mini Tiller
Troy bilt rototiller stalls when opening choke
The carburetor will need to be cleaned very good. New needle valve maybe float and new gaskets That should take care of the problem.
Apr 20, 2010 | Troy-Bilt Pony Garden Tiller
I need a forwward cable for an earthquake reartine rototiller #5020dm how to order. thanks
I googled Earthquake 5020DM tiller and show a site that has a technical manual. It has the diagrams and parts numbers. It looks like the forward and reverse cable are the same. You may have to call ARDISAM direct to get the cable.
Oct 02, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
