Question about Onkyo TX-DS676 Receiver
Onkyo sound popping / protected shows in the display
Lightening recently struck near our home. My Onkyo receiver is plugged into a Monster 3600 power filter. However, after the lightening strike, my receive now generates lots of noise and popping when I turn the volume up. Also it will pop, then show "protected" in the display, and an internal fan comes on. Is my receiver cooked, or can it be repaired?
  • Anonymous Mar 18, 2014
    I had an Onkyo receiver before with no problems until lightening got it. When I turn up the volume to medium, the system shuts off after a few seconds. I read that the regulator was bad. How do I get a new one installed?
  • 3,130 Answers
It depends on what happened to the receiver. Have you tried to connect up the unit to the wall socket yet, without the Monster power strip? If that does not help you, and the unit still gets pops and goes into protect mode, you have an issue with one of the output stages in the amp. I'm afraid that this type of repair can only be diagnosed by a tech who knows how to trouble shoot solid state amplifiers. You may also contact Monster cable, as if you can get the tech to agree with you on the cause of the problem, most of the Monster Cable power strips come with a warranty against this problem from happening and will pay for the repair. Good Luck
Posted on Aug 09, 2007
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
Hello! need help please my onkyo txnr616 when
possibly a problem with the receiver. first you could try a power cycle, unplug power cord of receiver for a minute then plug it back in and try again. if you still have the problem disconnect all speakers and see if the receiver will stay on.
Nov 03, 2013 | Onkyo TXNR616 Open Box 7.2-Channel 3D Home...
Onkyo HT-RC360 The receiver has a clicking sound when powered on. then turns off
No! I'am afraid not, if you have checked your wires carefully and it checked, the audio output semiconductors will require a technician to remedy the problem.
Apr 01, 2012 | Onkyo Audio Players & Recorders
My onkyo tx-ds575x lost power in a storm and now I get no audio from it. The sony bravia tv has sound but the onkyo won't send it to the speakers.
Please reset Onkyo receiver that will solve noisy sound problem, to reset the receiver, press and hold Video-1 button on unit and press Speaker-A button. Display will show *Clear* that means receiver has been restore on default settings, turn it On and check sound.
Hope this will help.
Apr 06, 2011 | Onkyo Audio Players & Recorders
Had a storm lightening struck something lights went out came back on but router dosnt have solid green light just flashing orange light modem dosnt see the router but if i plug in to laptop bypassing...
It appears lightening has damaged your router. Do you have a surge protected powerboard and do you plug all your computer equipment into this powerboard?
If you do not have a surge protection board, I suggest you install one to protect your equipment.
Aug 05, 2010 | Belkin (F5D7230-4) Router (587009)
Last night I finished hooking up my new Onkyo 7.1 HT-S5200 system. I used three HDMI cable to connect my TV, Blueray, and cable box. I upgrade the speaker wire to 16ga. The system is plugged into a Monster...
Turn everything off but the receiver. If it stays on turn another one on and see if it pops off if not continue. Most receivers have a pause start to prevent power surge. If it continues remove the protector and try the unit alone.
Oct 27, 2017 | Onkyo HT-S5100 Theater System
We had a near lightning strike and now my tv (sanyo model ht27744)doesn't want to come on.
Lightening may have caused a surge on your power lines to the house and to the outlet the TV was on.
Do other things work on that outlet? If not you tripped a power breaker.If they do work check this.
Unplug the TV for 2 min or more and plug back in.
Try bypassing your surge protector you had it plugged into. It could have died when the lightening struck.
(no surge protector?) Bet you'll buy one for your next TV.
Look for 3000 joules and up rating for a surge protector and insure it has protection for a cable/antenna input too.
If this doesn't work the TV may be fried or internal fuse blown.
Time to take it to a repair shop or depending on it's age (5 years+) it may be time to buy a new TV and surge protector.
Near Lightening strikes can effect appliances from several inputs that could be affected from outside like Power, Cable, Antennas, Phone Lines that come into your house.
Jul 06, 2009 | Sanyo Televison & Video
Just bought refirb. Onkyo 805, hooked up front l&r plus sub and getting no sound. I set up am and fm as per manual and connected a cd changer thru the cd in via rca cables. Radio shows a signal but no...
After few sec when you turn on your receiver did you hear a click noise ? if yes your receiver is OK not in protection mode if no click noise is output protection in that case you must return where did you buy for service and update firmware a lot of update
However you can reset your receiver and debug the DSP section ( digital signal processor ) as follow
To reset
1. Press and hold down VCR/DVR button, then press STANDBY/ON button when the unit is Power on.
2. After " Clear " is displayed, the preset memory and each mode stored in the memory are initialized and will
return to the factory settings, and turn to Standby mode.
Now turn back on and check if it work or not and make sure check input mode such as analog or coaxial or optical input if stil no sound then debug DSP as follow
To set in DSP debug mode
1. Press and hold down DISPLAY button, then press STANDBY/ON button while the unit is powered ON.
The version number of m icroprocessor is displayed only for 3 seconds.
8 1.05/07903A
2. Press TONE+ button within 3 seconds above, the version number of 1st DSP is displayed.
DSP 1st:
3. Press DISPLAY button while the 1st DSP version is displayed. The status of DSP and DIR will be displayed.
FFFFFF0 0 000
To exit
Press STANDBY/ON button.
Then unplug the unit for 30 sec then plug in it should work now if not you need to return it to 1 of the service center Onkyo in your town to repair it
Good luck
Nov 30, 2008 | Onkyo Audio Players & Recorders
Onkyo amp keeps turning off
Check your fuses sounds like one may of blownout
Nov 04, 2008 | Onkyo TX-SR875 Receiver
Tx-38/28 quartz synthesized tuner amplifier
hello surely there,s a problem in connection firs do this check your jbl even if they new with a baterry they pop up,now make sure you connect the monster wire into the outputs remember the wire is too thick make sure your getting contact in outputs...saludos
Jan 05, 2008 | Onkyo TX-NR801 Receiver
Onkyo TX-DS676 Receiver Logo
157 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
