Question about Whirlpool Washing Machines
Lsq7030lq0 Banging loudly during rinse cycle
Possible problem from symptom described above?
appldoctom
  • 311 Answers
SOURCE: GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to spin.you may have a blocked or failed pump.you get to it thru the frount.use a putty knife between the lid and the frount ,push the springs.top comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Posted on Jan 01, 2009
e-Guru
  • 3917 Answers
SOURCE: Loud noise during washing/rinsing cycles
Most likely the problem with your washer is a bad bearing on the drain pump. The pump has to be replaced.
- The part number for the drain pump is AP3447809
Thanks
Posted on Oct 09, 2009
kel1guy2002
  • 3740 Answers
SOURCE: loud banging noise during washing cycle. Sounds
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
This part is the most likely cause of the noise.
Thanks for using FixYa.
Kelly
Posted on Mar 07, 2010
  • 1382 Answers
SOURCE: loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Posted on Apr 08, 2010
  • 1937 Answers
SOURCE: My Kenmore 80 Series top
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Posted on Oct 01, 2010
Fisher & Paykel Aquasmart washing machine makes loud banging noise then stops during rinse/spin cycles
Your Aquasmart machine requires 4 new suspension damper rods & 4 top bands, these are a common problem for AquaSmart machines.
Feb 02, 2013 | Fisher and Paykel Washing Machines
Loud banging noise during rinse
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Jan 03, 2010 | Whirlpool Ultimate Care II GSW9650LW Top...
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
FWT449GFS2 making loud banging noises during final spin cycle
lxr6232eqo making loud banging noises during final spin cycle
Aug 31, 2009 | Frigidaire Washing Machines
Jan 01, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Boom and Bang Washing Machine
Bed sheets or comforters will often get out of balance in the spin cycle or during the rinse cycle. Throw some towels in there next time at least 5 big ones. They are engineered to take a little of this banging, it should only happen once in a while.
Oct 05, 2007 | Washing Machines
Banging during high speed spin cycle
Laco, drop the bottom front panel and see if all of the shocks are in tact on the tub assy. They just insert and lock by turning. If these are ok, check the back belt pulley. Sometimes one of the tines will split or crack and you will get this symptom. Catriver..post back.
Mar 04, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
