Motorola Mobility RAZR V3 Logo
thomas michaels Posted on Aug 05, 2007
Only has 9 speed dial numbers would like to have it unlimited
I can only assign up to 9 speed dial's on people I call; would like it to be unlimited, why would they only allow for 9 speed dial numbers??? H E L P!!!!!!!!!!!!!!!!!!!!!!!! Thomas
  • thomas michaels Aug 07, 2007
    No,
    You should have 999 speed diaL PLACES ON YOUR PHONE
    to see press 10 and then hash and it will show the 10th contact you added
    Thanks, but please explain the HASH(what button is that)???
    somewhat confused......thomas
Andy
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 10, 2007
 Andy
Contributor
Level 1:
Answers
Questions
0
Helped
457
Points
You have 999 speed dials. Only 9 of them can be used by pressing and holding the corresponding key. The rest you dial by entering the speed dial number followed by the pound sign and pressing the dial key. For example, to dial speed dial 107, you would enter 107# and hit dial.
Anonymous
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Aug 06, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
1695
Points
No, You should have 999 speed diaL PLACES ON YOUR PHONE to see press 10 and then hash and it will show the 10th contact you added
How to assign speed dial numbers
hold the preferred number to which you want to assign the contact to and press the assign contact or add contact option
Jul 15, 2015 • Cell Phones
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
I have a Motorazr V3M. It keeps assigning speed
all cell phone do this, but you can force the speed dial to #2 thru #9...
(for example to find who is in speed dial position number 49 press 49# on cell)
Howbto assgn speed dial number
press and hole the key which u want to assign a particular phon num ........then goto setttings->phon settings->contacts->speed dial->on/off
or
goto contacts->settings->speed dial->on/off
4helpful
STEPS NEEDED TO PROGRAM SPEED DIAL
For speed dial go to Main Menu >> settings >> initial setup >> Speed dial >> Phone Memory.
Than transfer numbers which you want to assign as speed dial in Phone memory.
Goto particular contact and edit the number and assign it as Speed dial.
2helpful
Assigning speed dials
leave the handset in the cradle and speakerphone off. press "program" button, (a constant beep will sound) press the speed dial number that you want to assign, then enter the phone number.
1helpful
Nokia 6085 how to speed dial
To assign a number to a speed dialing key, select Menu > Address Book > Speed
dial list, and scroll to the speed-dialing number that you want.
Select Assign or, if a number has already been assigned to the key, select Options >
Change. Select Find and the contact you want to assign. If the Speed dialing function
is off, the phone asks whether you want to activate it
FOR MAKING CALL
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number
in either of the following ways:
• Press a speed dialing key, then the call key.
• If Speed dialing is set to On, press and hold a speed-dialing key until the cal
Need manual for SBC Freedom Phone Model HAC FC2548
to programme speed dial just go to contact on your phone menu and select the conatct you want to speed dial and assign speed dialing number for the person or you type any number on your phone and press the harsh key like this (10#) and it will bring out the number assign to that spedd dial
2answers
Setting up a speed dial
from the website:
How do I set speed dial for one of my contacts? First, find the contact in your Contact List, highlight it, and press OK. Then select Options -> Speed Dialing and press OK.
Choose one of the numbers from the list and select Assign to assign it to your contact. You can now use 1-Touch Dialing for that phone number. Just press and hold that assigned one or two digit number instead of dialing the contact's entire phone number.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
