Question about Watches
Movado serial number lookup D36 7825273 35627
Trying to find a value on this watch I bought for my wife 28-30 years ago. The 14K band is to small now and we cannot see the face any longer, due to our age, not the watch. Please Help!
SOURCE: old Jaeger-lecoultre woman's wristwatch
I would be happy to help. The problem is it is impossible to determine the value without seeing the watch(condtion is paramount). your best bet is to ship it Registered mail return receipt requested that way you have proof that it was received. I would think that that $5,000.00 insurance would most probably protect you. email me if you have any questions
Donald McPherson CW
www.finewatchmaking.com
Posted on Oct 21, 2007
  • 77 Answers
SOURCE: Adjusting Band Size on a Movado Amorosa Watch
there are little pins holding them in place pop them ou and add or delete couple links.
Posted on Feb 11, 2008
SOURCE: i need help
It probibly is a tri-fold clasp or a "hiding clasp" When you look at you watch can you see a clasp? If not you just need to pull from the middle if the back of the band. One end will open to the left another will open to the right. Don't be afraid to pull on it, that probibly is the main problem your having. Movado makes a solid band that can take some punishment
i
Posted on Aug 13, 2008
  • 16 Answers
SOURCE: Broken Watch band
you probably just need a pin to secure the links back together. an authorized Movado retailer will have the tension or screw pins to put the band back together. They can also order additional links if needed. you can find a local retailer on www.movado.com
Posted on Jan 23, 2009
escapement
  • 2334 Answers
SOURCE: how to adjust a movado band
If there are screw on each side- you have to use two screwdrivers simultaneously. If not- read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together. Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!! Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Aug 14, 2009
Find out if a watch i have is worth money
Check to see if your watch or one closely resembling it, is for sale on Ebay. This generally gives an idea of value, at least in terms of resale and value. Watches, other than Rolex and very high end types, don't have very good resale value. Of course, all of the value may be in the diamonds or 14K cases, no matter who is the maker.
Dec 13, 2014 | Waltham Watches
Does the Movado ladies watch serial number 74259821 836092 have a solid 14K wrist band?
The 74259821 is definitely a 14k solid gold watch. I have one, too, and need an extra link for it if anyone out there has one. 267465b2-5058-4a86-99d3-8e2eb936415b.jpg 83ef6643-49bf-4f76-97f1-639d71b4c025.jpg
Sep 15, 2014 | Movado Museum Watches
I need a valuation on a ladies gold movado watch. Serial number A63165
Hello there, the serial number on a Movado watch is usually unique to each watch and therefore a watch cannot be identified by that. Here is a picture of all the gold ladies Movado watches which are presently available. I have numbered them 1 - 8 accordingly.
1 and 2 are both tagged the Amorosa and are valued at $895 and $1395 respectively.
3 and 4 are both tagged the Concerto and are valued at $2495 and $1495 respectively.
5 and 6 are both tagged the Bellamoda and are valued at $1495 and $1095 respectively.
7 is the Harmony and is valued at $895
8 is the Rondiro and is valued at $1495
If your watch is not on the list above then you might want to send it to the nearest Movado authorised dealer to confirm if it is original or a knock off.
Hope this support has been helpful?
Thank you for visiting FixYa
Sep 10, 2011 | Watches
Good morning. I am considering purchasing an antique omega watch: 14k white gold AA7442 562738 case serial number The movement is from the Omega watch co.. 17 jewels swiss. Serial number 23625437...
The repair to the winder may be only £30.00 but will the watch then work well.Parts for old Omegas can cost a premium and the watch may need a service.A service to an Omega by a good watchmaker will cost £170.00 ish and if it needs parts this will rise.
As to value if its 14ct on a bracelet the gold is worth about £12.00 a grm so if its 30g then the gold is £350/£400.00
Its hard to say what to pay without knowing if the watch works well,if it needs £200.00 spending on it the value is reduced to little more than the gold value so id weigh the watch work out a gold value and then a small amount.
If you need a repair try www.rolexrepairs.co.uk they offer a free estimate.
Regards
Aug 12, 2010 | Watches
My watch battery low. watch name MOVADO series 800
mcdevito75 here, Movado a FINE watch, BEST BET, look for a small watch repair shop in your area to change the battery, Movado watches have a very good over all value and any damage can lessen that value, not to mention the jewelers screwdriver you"ll need to change that battery.
Jul 09, 2010 | Movado Series 800 Watch
I have a 1966 Bulova and I am trying to find the value of it. Using the serial number to even find this watch on any Bulova website is not working. The serial no. I use says its not found. Why? This Bulova...
mcdevito75 here, Best Bet, visit a small watch repair shop in your area, But I;ll tell you I have a little experience with older watches, fact is I just finished basic work on a frieds 30 Jewel 65 Bulova and couldN;t find anything online except at various Antique sites that I didn:t write down, your 30 jewel Bulova along with the one I fixed for a friend of mine is worth at least what it cost when brand new----over $100.00
Jun 30, 2010 | Watches
Bulova 14k Solid Gold woman's watch. Swiss 17 Jewel unadjusted Bulova Watch co. 6AH S/F dial with 3XS under the S Watch Case: inside on back-Bulova 14K solid gold New York Watch band: Kreisler Quality USA...
This sort of information is only likely to be available from an authorised dealer.
If you go to the Boluva web site, you will be able to use their dealer locator to find the one nearest you.
Mar 17, 2010 | Bulova Ladies 14K Gold Collection Watch
I need a new leather band for my Concord watch.Where can I get one?Numbers on back of watch are14 25 1470.1 then under that 1261034.
Concord is part of the Movado group. They do not sell replacement parts to just anyone. So if you want an original band you will need to take it to an Authorized Movado/Concord retailer. Or if you wanted to save some money you can take it to a watch repair business that sells and replaces watch bands. Speidel makes some really nice watch bands.
http://www.concord.ch/servicelocator/index.php
Jan 07, 2010 | Concord Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
