Question about ASUS P4XP-X Motherboard
P35 1k1 1fd9 network card - ASUS P4XP-X Motherboard
I have installed a network card into a pc on a LAN.however the pc fails to connect to the network since no link light appears on the card.what steps would you take to troubleshoot and fix the problem
insert the network card into PCI slot
Install proper drivers
Restart computer
Connect to Network
If this dont work then there is problem with network card purchase a new one
Dec 18, 2013 | D-Link DFE-530TX+ Ethernet ED100W Network...
Unlock my phone
If the Nokia X6 16GB phone,displays invalid sim card message on the screen it is locked to some network.Please find out the network and country it is locked now.If it is locked to network,it will not accept other network sim card.But you saying it is accepting other networks sim card.How many network sim card have tried inserting in it?If you tried only one network sim card and it accepted that it is locked to that network.You can also try using some other network sim card.If it displays invalid sim message again.It is under network lock.To unlock it use unlock code.Visit the site Wickedunlock.com get code and unlock it easily.
Jun 11, 2013 | Nokia X6 16GB Cell Phone
It will not read my tmobile sim card
It's not reading Only T-Mobile Sim card ?It's not reading other sim card also Expect Only One Sim card?
If it reads only Sim card and not reading Other Sim card like for Example T-Mobile,AT&T,Orange etc means it locked to Network ,you have to Unlock it To use any GSM Network Sim card,What is Mobile Phone Brand and Model?Find the Network ,Country it locked now? then first please You can find it locked To GSM Network or CDMA? Network CDMA Network means You cannot Unlock t to use any gsm Network Sim,Gsm Network Lock means You can Unlock it to use other Network Sim card...You can Unlock it using the Unlock code,You can get the Unlock code and instructions at here
Unlocking4u.com and Unlock it from Network Lock,then you can use with T-Mobile Network surely.
Aug 13, 2011 | Cell Phones
WHAT SPEED IS IT?
This is an older network card, and has been discontinued by DLink.
The network speed on this card is only 10MB
Compared to new network cards which are 1G this card is 100 times slower, or 10 times slower than older 100MB network cards.
Feb 26, 2011 | D-Link DE-528 Network Adapter
My network card is only allowing 54mbps , I have 1.5gig dsl with a 300mbps router Do i need a new network card the driver is updated to last update
Your wireless network card is more than sufficient to handle the bandwidth provided by your DSL connection. A "1.5" DSL connection refers to a 1.5Mbps DSL line. Your network card is an 802.11G network card. Simply put, your network card will only run at a maximum of 54Mbps, far short of your 802.11N router's maximum speed, but provides more than enough room for the bandwidth provided by your Internet Service Provider. Gigabit connections (connections with speeds measured in 'Gbps') are almost exclusively for private networks or corporate networks with Fiber Optic connections.
In layman's terms, you can get a newer network card for your computer that will improve the speeds between your laptop and any other computers on your network, but as long as your network card is supported by any modern operating system, odds are it is able to transfer data fast enough to keep up with your DSL connection
Nov 25, 2010 | Toshiba PA3235U-3BTM Network Adapter
How to fix a network card
Please include information like:
-operating system on your computer
-is the networking card damaged or just not working in YOUR computer.
-error messages you received while trying to use the network card
-brand and model of network card
If you include this info I can help you with your problem.
Aug 23, 2010 | Dell Ethernet Card Network Adapter
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Bad network card in a Dell Dimension 8200. What
You can purchase ethernet card "realtelk ethernet lan card "
Realtelk is best network card right now.
Also Dlink network card is also good.
Jul 24, 2009 | Dell Dimension 8200 PC Desktop
Network adapter not being recognized by pc
you need to disable the old network card go to the computer setting (CMOS) and disqble the network card (you are having a hardware addressing conflict.
Jul 01, 2009 | Computers & Internet
ASUS P4XP-X Motherboard Logo
23 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
