Question about Philips HTS6100 Home Cinema System 5.1 system, DVD player, HDMI, USB
Phillips Repair Manual
Power supply problem
2 Suggested Answers
  • 8457 Answers
SOURCE: I have a phillips lcd
U have all the tools like a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders,also can do basic soldering and understanding of basic electronic?Yes,take out the tv power supply board,by checking it carefully ends to ends looking for dying capacitors parts,it alway bulging up on it tops or puffing up on it tops are the most common failer on the tv power supply board.By replacing all those dying capacitors,u can check the Zenith power supply board for capacitors for parts to replaced.Capacitors are very important must have the same exact micro ferit ok the voltages 5 or 10 voltages higher no problems.Take out capacitors and putting in different capacitors or new capacitors to a board must make sure polarity - + putting it in correctly to the board or will causes explosion,kill that new capacitor and more damaging to that board or the unit u tries to fix.
Posted on Feb 17, 2011
I have a Phillips flat panel tv that won't come on
The clicking sound is the switched mode power supply trying to power up the TV. This problem is usually caused by parts called capacitors on the power supply board going bad. You can repair the board yourself by replacing the capacitors. On this model there are 4 main capacitors that will need to be replaced. If you feel that you can do the repair yourself then get back with me and I will help you get the right parts, if not you can take the unit to a repair center near you and they can replace the power board. tech@ccl-la.com
Jul 24, 2012 | Televison & Video
I have a phillips lcd hdtv. When I turn it on the light blinks 6 times. I'm sure its the power supply board, my question is how do i repair the power supply board without replacing it? I have a power...
look ON THE POWER SUPPLY FOR SWOLLEN CAPASITORS. usually 2 RIGHT BY HEAT SINK. VALUE VARIES... REPLACE ANY SWOLLEN CAPASITORS AND SHOULD SOLVE PROBLEM
Feb 17, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Dell w4201chd 42" Plasma Tv.
OK, you need to replace the Power Supply Board.It is made by Samsung the number on the board will be LJ44-00110A. The Replacement number is LJ44-00019A,the cost is $349.00,however this part also crosses to a Phillips number 99500042146 which sells for $289.00 these are all the same board.I use the Phillips Board.Most repair shops will not do any research to locate these boards due to time and volume of repairs the have to deal with.Most call Dell and they won't give out repair info.They require it to be sent in.The Phillips board can be purchased from any NAP distributor.
Feb 11, 2009 | Dell W4201C 42 in. Plasma HDTV
3500 phillips home theater system
it is possibly a power supply failure have you noticed a ticking noise you will have to be close to hear this if it ticks your power supply is tripping and needs rectification, if in uk do have workshop for repairs if you pay carridge will evaluate and repair
post reply and will be in touch
Regards
Brian
Aug 12, 2008 | Audio Players & Recorders
Phillips Plasma Error
That unit is a BP2.2UAA chassis and from the sympotoms you're describing you have a power supply problem. The power supply is an smps (switch mode power supply) Philips p/n# 996500033880 and available at Vance Baldwin for $473.58 plus shipping, which includes a $250.00 core which you can get back when you ship them the old part.
If you buy the supply yourself and attempt the repair it's a simple plug-n-play but you should also check the Y & Z sustain boards for possible shorting.
Bill
May 19, 2008 | Philips 50PF7220A Television
Power supply problem with Phillips 46pp8621/79
Your chassis is the DPTV 325 you can get the factory training manual for your set emailed to you at the following link. It cost 12.99 but comes with unlimited tech support if you need it. The manual is listed as DTV300 series training manual its has the trouble shooting proceedures and diagrams that you would need. heres the link.
http://servicemanuals.vstore.ca/
May 11, 2008 | Televison & Video
Please help.
A virus is present in your mp3 dev clean the virus it should be fine . Format your mp3 dev thorougly more than once and use the phillips cd accompanied .
May 09, 2008 | Atech Flash Technology AFT-6551 P4 ATX...
Phillips 37FD9944/01S Plasma TV - Power Supply
dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
Philips HTS6100 Home Cinema System 5.1 system, DVD player, HDMI, USB Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
