Question about Philips 42PF5521D 42 in. HD-Ready Plasma Television
Lines across screen when using View On Demand channels
Hi, I've just got a Philips 42PF5521D. I've got Tiscali/Homechoice cable. When I access any View on Demand, Movie rental channels, etc. the screen gets horizontal lines/bands across it. This stops as soon as you exit out of the VOD channels. All other viewing is fine. Any help would be appreciated.
  • 476 Answers
Could be a couple of things causing this.
1) Obvious, but I assume that you subscribe to these services, because otherwise it could be the encryption.
2) Make sure that you have the set-top box connected directly to the TV, and not through an external recorder (VCR, DVD etc)
This would be a problem if the services were copy protected in the same way DVDs are.
You could also check the settings on the set-topbox. Make sure the video output is set to RGB.
Posted on May 03, 2008
SOURCE:
I cannot change the channel on Westinghouse TV. Model SK-19H2105 - Tried to do the fix mentioned for channel scan - cannot find the channel scan.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
(OSD)
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
Aug 16, 2016 | Westinghouse Televison & Video
Vizio vx37l hdtv10a
This could be a problem at the cable source end.
Oct 25, 2017 | Televison & Video
Hi I'm looking to install a DG834G router to give wireless access but the only instal disc is from AOL and I'm not with them anymore, I have tiscali broadband. How do install the router if it won't plug...
Try NOT using any install disk.
Turn the TISCALI router off.
Turn the NetGear off.
Use an Ethernet cable to connect from the LAN port on the TISCALI router to the WAN port on the router.
Use another Ethenet cable to connect from one LAN port on the router to the network-port on your computer.
Turn the TISCALI on. Wait 60 seconds.
Turn the NetGear on. Wait 60 seconds.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway....192.168.123.456
Note that the '123.456' will be some other numbers.
Start Internet Explorer.
Type http://192.168.123.456 (substitute the current values)
Login to the web-server running on the router.
Run the "Wireless Networking Setup Wizard"
to configure a SSID, an encryption-level (use 'WPA')
and a password for your network.
After the router restarts, you should be able to get wireless access, using the SSID and password that you configured your router to use.
Sep 29, 2010 | NetGear DG834G Router
Inference lines across screen on upper channels
The problem is actually not likely to be the set. The symptoms you are seeing are usually caused by a bad ground connection somewhere in the cable run. Check the connectors at both ends of the cable to be sure that they are secure. There is an open ground somewhere in the signal path. If you have cable or satellite, it could be outside the house as well.
Dan
Feb 04, 2009 | Panasonic TH-50PX75U Plasma HDTV
26PFL5520D/50 DVT PROBLEM
If the lines across the screen are made up of coloured blocks, then the problem is likely to be a weak signal.
Digital channels are broadcast in groups called multiplexes. Sometimes one multiplex may have a weaker signal than others, and so you experience problems with up to 6 channels when all others are ok.
If it is only one or a few channels then just wait and see what happens, because it may be transmitter works.
If you have problems with all channels it could be a connection or antenna problem.
If the lines are just straight lines, then try resetting the TV as follows:
Switch on the TV
Press and hold the menu button on the side of the set. The settings menu will appear. Hold until the menu disappears again.
When you release the button, the TV will take up to about 90 seconds and then reset.
The TV will then show the original screen when the TV was new.
Press ok when shown.
Set language and country settings.
Move down the list and press ok to re-install all channels.
Feb 22, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Siemens gigaset SE587
http://www.youtube.com/watch?v=Lp1aHe3jGeU
Jan 30, 2008 | Computers & Internet
My philips got green light on no pic.
Press and hold the menu button on the side and hold for five seconds, that will reset the tv ------------- do this after you have checked your manual for other troubleshooters, you know, the obvious 'correct channel i.e EXT1, EXT2, TV'
Nov 06, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
'F' displaying on screen and remote not responding.
Excavated with Google from Philips website: " When a letter F appears on the right hand corner of the screen it means the television is in factory mode. To exit from factory mode, press the 'VOLUME -' and ?CHANNEL -? buttons on the TV set simultaneous for 5 seconds. " Hope this helps Michael Junge
Aug 04, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Horizontal lines
http://home.tiscali.nl/m.majoor/tv__matchline_service_mode.htm Sounds like you need go this site, enter codes and re callibrate your TV to the settings. If this does not work - then sounds like you need tv repair man replace caps or solder bad joint. Miyan sung, former philips rep man, Korea.
Aug 29, 2006 | Philips 32PW6506 32" TV
Philips 42PF5521D 42 in. HD-Ready Plasma Television Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
