Question about Schwinn Cycling
How to tighten bike pedals on a schwinn wayfarer
My pedals came loose and are now wobbly when I ride, how do I tighten them?
  • 50 Answers
SOURCE: My Schwinn 230 Recumbent bike makes a clanking
try the bearings.
Posted on Mar 03, 2009
goalie39
  • 469 Answers
SOURCE: How to disassemble crank bearing on Schwinn Mesa Mountain Bike
You wil need a couple of special tools, or be fairly creative with the tools you have.
  1. remove the dustcovers in the crank arms at the crank axle
  2. loosen the crank retaining nut/bolt.
  3. thread in a chank puller and pull the crank arms.
  4. remove the lock ring on the adjustable side of the crank axle (Requires lock ring wrench)
  5. remove adjustable bearing cup.
  6. remove axle and bearings
  7. replace or repair as needed.
Once you have it opened up ou can determine if you need new bearings or crank axle.
to assemble, reverse above procedure, insuring bearing play is minimalized.
Hope this helps.
Ed
Posted on Apr 19, 2009
billfox1966
  • 231 Answers
SOURCE: I HAVE A MGX MOUNTAIN BIKE. WERE THE PEDAL ARE
im certain that model has a 3 piece crank set up. the inner crank bearing jam nut has loosened up or the bearings themselves have gone bad.first check to see if its tight, if it is then it will require a replacement set of bearing that are a pretty standard size to all bikes and can be purchased at nearly every bike shop.
Posted on Jul 09, 2009
smokinB
  • 55 Answers
SOURCE: My Schwinn hybrid bike makes a popping noise in
Your pedal berrings are going out try replacing it.
Posted on Jul 14, 2009
  • 1788 Answers
SOURCE: Bad crank bearings can move crank arms small amount.
clicking can be a stiff link in your chain.
Posted on Aug 04, 2010
Why does my bike paddle so hard
Are you riding or rowing? Schwinn bikes pedal, row boats paddle
Apr 23, 2014 | Schwinn Cycling
Pedal slips while riding
loose sprocet on rear axel shaft skips every so often
or slips
Feb 26, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
How do I get the gears to work again on my Schwinn Mesa GSX Mountain Bike?
The shift cable is likely too loose, but there are multiple items to tighten, lubricate and adjust on just the derailleurs, let alone the rest of the bike, before it's safe and ready to ride. I would suggest you get some assistance from a more knowledgeable friend, a bike co-op or a bike shop.
May 18, 2017 | Cycling
The rear 7 speed sproket on a schwinn jaguar has quite a bit of play in it and wobbles how do i tighten it
Unless you want to spend snout $80 on special tools, take it to a bike shop. They will tighten it properly for very cheap.
Jul 23, 2011 | Schwinn Cycling
I need to tighten the chian on my schwinn airdyne.
Two places to tighten the chain and it requires you to loosen the nuts on BOTH sides of the bike, almost at the same time. Start at the fan wheel (top) of the bike. First thing you need to do is to loosen the little nut at the hub of the fan wheel on both sides. Unscrew it almost to the point of taking it off, but leave it screwed on the end of the bolt so it will stay on the bike. Then use an adjustable wrench to loosen the nut a bit on one side and then do the same on the other side OR use both hands and loosen both at the same time by unscrewing with adjustable wrench in opposite directions on both sides. Once the wheel is loose, you want to sit in front of the bike and pull both of the large nuts at the same time toward you and the chain will tighten. The goal is to have the fan wheel centered and for you to be able to see about 1/4" inch of clear gap behind the nut on both sides. Then use your fingers to tighten the nuts to the frame just enough until you can use the adjustable wrench again. I have sometimes used a flat head screwdriver to insert into the gaps to prevent the chain from loosening up. The tighten the nut on both sides of the bike. Be sure you tighten the little nuts as well (they are called chain tensioners). That SHOULD do the trick. However, if your bike chain is still too loose, you need to do the same for the chain at the pedal area, That requires the same thing all over again, but in most cases, the chain loosens at the top part of the bike (fan wheel place). However, if you do work on the pedal area, you want the chain to be pushed toward the fan and not toward the **** side of the bike. It may sound crazy but that's the only way to tighten the chain. give me a thumbs up with my solution.
Feb 18, 2011 | Schwinn Original Airdyne
My Father has a schwinn Airdyne. the pedal was loose, I bought a new piece that fits through the pedal, replaced it but it is still loose. I think the medal in the crank wheel is worn...... Because the...
There is a metal shim needed in the bike/pedal that has to be tapped in to keep the pedal tight. If you dad has used the bike for several hundred miles and/or his feet might actually bend the pedals over time (weight), it is possible the metal piece that the pedal attaches to could become bent slightly, and I have seen a few bikes, that need to be taken to the bike repair store (call a large bicycle/itness store) that has a good repair shop and they often can repair these, but rarely less than $125 for an Airdyne repair/tuneup.
The pedal mechanism is loose when try to ride
Can you be more specific? There can be several reasons for this. Pedal arms can be worn out, hub in fan can need overhauling. Does the chain move with the pedals? Are the pedal arms loose or the pedals themselves? Pedal hub could also need overhauling. If the overhauling seems to be the issue, best bet would be to take the machine to a local Bike shop, If you're pretty handy, and can do the repair yourself, give me more specific details and I can suggest better instructions on repair.
Mike
Dec 27, 2010 | Schwinn Original Airdyne
That would depend on the style of bearings (loose ball or caged balls vs sealed bearings) and possible bottom bracket damage.
Either way, a Bike Shop mechanic would probably need to assess it for you. Special tools are usually involved.
http://parktool.com/repair/byregion.asp?catid=61
May 23, 2010 | Schwinn Mesa Gs Mountain Bike
Men?s Schwinn 700C Prelude Road Bike Assembly
Pedals can be purchased in pairs and some road bikes do not come with pedals. They have 2 different axle sizes 9/16" and 1/2". There are road pedals and road clipless pedals.The ones with clips and quick bindings require special biking shoes that the cleats clip into.Quick releases come in various lengths for front and rear wheels depending on what wheel you have. This all means a trip to your local bicycle dealer. They will match the pedals to the axel size you need and the type of riding you will be doing. For a little extra cost they will install them.They will also match you up with the proper length of quick release skewer you will need and show you how to install and tighten it properly.Remember to take your bike and the front wheel. Hope this helps. Good riding.
Mar 15, 2009 | Schwinn Midmoor Men's Hybrid Bike
Cycling Logo
23 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
