Question about Charter Cable Cox Cable URC-8820-CISCO 4-Device Back Light Remote Control Universal AUX DVD TV
Codes Looking for the 4 digit code to a Proscan TV.
Need code for ProScan universal remote
Proscan HDTV Codes = 1000
Proscan TV Codes = 1000, 1008, 1068, 1094, 1108
Proscan DVD Codes = 2118, 2144, 2205, 2319
Proscan VCR Codes = 3000
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your ProscanTV can be controlled with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc...
Nov 22, 2016 | Proscan Televison & Video
Proscan Remote Control / Codes
0382,0376,0361,0000 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 03, 2013 | Televison & Video
NEED SET UP CODE FOR A "ONE-FOR-ALL UNIVERSAL REMOTE (4 DIGIT) REMOTE # URC-1056 1303...TV PLDE3992A TV IS PROSCAN
Check these codes. 0009 0186 0217 0206 0163. If you wish to get more codes, check this link.
Feb 12, 2013 | Televison & Video
Remote control
These remote codes also depend on what the exact make and model of the remote control is that you are using. These remotes can also use 2,3,4 or even 5 digits. The other factor is that some universal remotes will recognise the code for your proscan TV - but others will not depending on how they are programmed.
I will give you the most common 4 digit codes for Proscan and hopefully these work for you. If not please post up further detail on the remote control - exact make and model no. that you are using in order for us to solve the problem.
Common Proscan TV codes:
0000, 0015, 0031, 0107, 0162, 0163,1000, 1008, 1068, 1108, 2010, 2118, 2144, 2205
If this works for you please do rate my answer using the thumbs. If not please provide more detail and I will be happy to respond.
Thanks for using FixYa.
Jan 08, 2010 | Proscan 19LA25Q 19 in. LCD Television
Comcast remote won't accept codes for Proscan TV
I had the same problem. I have the 40 inch Proscan and they supplied a remote control guide for comcast. It was only 4 digits and it did not work. I called Comcast and they did not know. I found it needed 5 digits so I added a 1 and it worked The code is 10178. Hope it works for you.
Jul 21, 2009 | Sylvania LC420SS8 LCD TV
I have a Proscan 40 inch LCD tv and i can't program my cable remote. I've tried the 4 codes that were supplied by my cable company for my tv but none worked. I also tried the manual search but that...
I had the same problem and code 0178 worked for me. It isn't anywhere that the other codes are on the internet, I just found it on a message board somewhere.
Good luck and I hope this one works.
Jul 01, 2009 | Proscan 32LB30H LCD TV
Program Directv remote to operate the Proscan TV
The Proscan is an RCA product so the codes are:
10047, 10466, 11347, 11447, 10018, 10019, 10038, 10047, 1090, 1135, 10679, 11047, 11147, 11247, 11347, 11447, 11547
1. Turn on the TV
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under TV flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of TV being set up. If performed correctly, the green light under the selected position lashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
If this helps please rate my response. Have a wonderful day!!
Jun 27, 2009 | Proscan Televison & Video
Remote code for comcast dvr/proscan tv
I was having the same problem with my 40" Proscan Tv. I had to go to Comcast and get the remote with the gray OK button instead of the red. I could program my DVD player with a 4 digit code so this remote worked when I put in the 4 digit code Proscan sent with the TV (0178). This was the only solution I could find . They do have the remotes with the gray button but you might have to be very persistant to get one with the codes for the rest of your electronics.
May 23, 2009 | Samsung DVD-HD845 DVD Player
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Oct 19, 2007 | Proscan 32LA30Q Television
Charter Cable Cox Cable URC-8820-CISCO 4-Device Back Light Remote Control Universal AUX DVD TV Logo
Top Charter Cable Televison & Video Experts
Electro Med Services...
Are you a Charter Cable Televison and Video Expert? Answer questions, earn points and help others
