Question about SUNNILAND CORPORATION Sunniland 20 LB Chinch Bug Granules Controls Chinch Bugs
Scotts rotary edge guard settings
The package doesn't give the settings for a scotts rotary edge guard spreader for the chinch bug granules. Help?
What setting should I use on Scott speedy green broadcast spreader for 8 lbs /1000 square feet
Hi Jack:
Depends on the size of the granules in the product that you are using. There should be a table on the package.
Here's the link to one of the Scott information pages
http://en-ca.scotts.com/smg/gosite/Scotts-v2/spreaderSettings
Cheers.
Oct 19, 2015 | Garden
I have a scots edge guard spreader and need to put on weed and feed at 4 lbs per 1000 sq feet what setting on spreader should I use
Hi Mike:
The setting will depend on the size of the weed & Feed pellets.
The package usually has setting instructions on it.
If all else fails, the rate is 1 lb per 250 square feet.
Mark out an area about 10 ft by 25 ft long.
The spreader cast is about 5 ft, so down and back should use 1 lb.
Set the spreader at a minimal rate and see how far 1 lb goes, then adjust the setting accordingly.
May 22, 2015 | Scotts Garden
I have Scotts deluxe edge guard. How go check calibration
The Scotts Edgeguard Spreader is calibrated at the factory. This spreader cannot be calibrated, and shouldn't need to be. For further assistance, call Scotts at 877-465-5160
Hilary @ Scotts
Aug 14, 2011 | Scotts Company Scotts Lawns Edgeguard...
Where can I get a wheel assembly?
I am sorry to hear about the problem with your spreader. Sometimes we have replacement parts for our spreaders. Please give Scotts a call at 1-800-543-8873 at your earliest convenience to check part availability. Hilary @Scotts
Aug 05, 2011 | Scotts 74434 "deluxe" Edge Guard Spreader
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
SUNNILAND CORPORATION Sunniland 20 LB Chinch Bug Granules Controls Chinch Bugs Logo
77 people viewed this question
Top SUNNILAND CORPORATION Garden Experts
Dennis Key
Dennis Key
john h
Are you a SUNNILAND CORPORATION Garden Expert? Answer questions, earn points and help others
