Question about Whynter WC-211DZ 21 Bottle Dual Temperature Zone Wine Cooler,
Blinking temp lights - Whynter WC-211DZ 21 Bottle Dual Temperature Zone Wine Cooler,
Blinking 'Check Collector Cell' light
which model XL series do you have? There is obviously something shorted or arcing on the plates of the cell. look at the plates and see if they are laying flat and the wires are all still attached across the front of the cell. A loose, sagging, broken or bad contact on the end plates will cause the bad cell lights. clean off the area where the cell makes contact inside the unit. The metal strips that run across the ends of the cell make contact with the plates inside the cell and get their power from them, dirty contacts in any part of these contacts will cause the problem. Even a bad contact from the end cap to the plates inside the cell will cause this. Try wiggling the cell around, kind of push on it on edge to get the plates to shift slightly and clean the points where the plates touch the outer strips on the sides. Check for arcing with the lights turned off,
Oct 20, 2014 | Oreck XL Professional Air Purifier
How do you reset the machine, to get rid of the flashing red light after changing the filter?
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking.
Dec 09, 2010 | Filter Queen Defender Air Purifier
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply..
if in dry mode let the unit run for an hour and it will stop blinking ..
Jun 28, 2009 | Oreck XL Professional Air Purifier
Ionic breeze quadra constantly blinking cleaning overdue, evenghough it is clean.
If it still works after you cleaned it, consider yourself lucky. If light blinking bothers you, just put a piece of black electrical tape over it and enjoy it. That unit has been driving me nuts for years. I cleaned mine and now it doesn't work at all. A blinking light I could put up with, with a little tape. Enjoy it because it still works.
Apr 05, 2009 | Sharper Image Professional Plus Ionic...
Red light keeps blinking
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Nov 15, 2008 | Oreck XL Professional Air Purifier
The blue light on my ionic breeze is blinking.
The ionizers were recalled by Sharper Image due to a lawsuit that they lost forcing the company into chapter 11.
There is a thread on this website with further details.
Sep 13, 2008 | Sharper Image Professional Plus Ionic...
Blinking blue light on ionic breeze s1871
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude! hlaytos@aol.com
Mar 22, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Blue lights are blinking
I have the small version Quatra our older unit finnally died so sharper image sent us this smaller version. This will be the 2nd or 3rd replacement with in a week of getting a repalcement everytime the light starts blinking before it can even get dirty.
Mar 20, 2008 | Sharper Image (V23145) Air Purifier
Whynter WC-211DZ 21 Bottle Dual Temperature Zone Wine Cooler, Logo
77 people viewed this question
Top Whynter Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Whynter Air Purifier Expert? Answer questions, earn points and help others
