Question about Durabrand DU1901 TV
AV doesn't allow me to see the movie
When the TV is on Aux mode I get a black screen with white squares going across the screen. I can hear the movie but cannot see it.
    Problem Solver:
  • 19 Answers
Are you sure that you connect exactily av mode not aux mode,if you flow the instruction.
Posted on Nov 02, 2007
  • festo msigallah Nov 02, 2007
    try connect to the tuner then play movie,then seach you tv.
SOURCE:
My nintendo wi system when i turn it on the home screen is in black and white and fuzzy what is wrong
Well I think that it might be the av cables that are causing it to be in black,gray and white then. Or the tv might be having an issue with the rca jacks on the tv where you hook up the av cables or it could be the aux or video 1 2 or 3 that is not working so try another video or aux number too see if it will make a difference.
Jan 06, 2014 | Nintendo Super NES Console
My wii when i turn it on it only has lines going across the screen.. about a week back it was saying something about the memory. now it wont load the wii menu nor will it load any games... if anyone knows...
Picture Is Black and White or Does Not Appear
Situation:
The console powers on and shows a black and white image on the television screen
The console powers on and there is no image on the television
What to do:
Determine whether the Standard AV Cables (packaged with the system) or the Component Cables (sold separately) are being used.
AV Cables
Ensure the yellow, red, and white cables are connected to the correct corresponding inputs on the TV. (How To)
Try another set of inputs on the TV, or hooking the Wii console up to another TV.
If the TV does not have the yellow, red and white inputs, it will most likely have component inputs which allow standard AV cable use. Try these AV hookup steps. (How To)
Component Cables
Ensure the red, blue and green video cables are connected to the correct corresponding inputs on the TV. (How To)
Still Not Resolved:
If the television is continues to show a black and white image when powering on the Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further.
Was this information helpful?
Nov 02, 2012 | Nintendo Wii Console
Im trying to set up my tv, it was given to me as a gift, my uncle was using it it works i can change the channels but when i try to work my dvd player with it, only the audio comes on the screen stays...
Please few things...
1- Make sure audio and video wires are hooked correctly in AV input of tv and you selected that AV input in tv with its remote.
2- Also check your dvd has not been set on progressive mode if you hook dvd player through yellow-red-white wires with tv.
3- if dvd player is set on progressive mode, then hook it with tv by component video input, red-green-blue for video and red-white for audio.
Hope this info will solve your problem.
Thanks.
Mar 17, 2010 | Toshiba TP55H60 55" Rear Projection...
After connection my pc to the tv, how do i get my screen on my pc to show on my tv....i pressed f5 and it's not working it keeps restarting my movie on the pc instead of it showing on the tv screen
Connecting this up will be easy. What you do is get a yourself a set of the right, for your setup, cables. That uses EITHER one of the formats, of these described, below. You will need, either, a THREE way Cable, or three separate " Coaxial Cored" Cables with RCA PLUGS on them. ColoredYellow, (Video) Red, & White. (Audio) AV. OR If you have SCARTConnection Sockets, it's a big Black Socket at rear of unit(s), you get aSCART Cable.& It's all inside. Now some units, use a standard calledComponent Video, that uses, a Green, Red, & Blue Plugs. Now, with the Component setup, you will also ,need, Two more Cables, for the AV Audio. these are, Red & White.(So with Component Video there are 5 Cables/Plugs in all). In any event ALL Cables go Color to Color, at each end, plugging into the corresponding Colored RCA Jacks, on either machine, or VCR or TV. Now if you have SCART, then it simply plugs in only one way. It is that simple. So connect up with the leads your set uses, and select the correct "Input" from TV/Remote, it is NOT on a "Channel" it will be on AV, AUX, and Press "Play" on VCR/DVD whatever.... should be all go.
Feb 21, 2010 | IBM ThinkPad T41 Notebook
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
Game mode not working properly on sylvania tv
did you try to switch the tv modes Ex. my tv has av 1 av 2 comp 1 comp 2 does it have those modes
Apr 21, 2009 | Sylvania Electronics - Others
Help
how are you connected to your tv? if your are connected in HD mode (hdmi cable) you will only get a 16:9 picture... SD mode (AV cable, S VIDEO cable, Component AV cable or SCART) will transmit a picture of 16:9 or 4:3 (4:3 being the old 'square screen' mode)
Oct 01, 2008 | Sony Playstation 3 (PS3) Console
Black square in middle of tv
He, he. Somebody activated the subtitle mode on the remote. Desactivate the CC mode on your menu and it'll go away or at least if you want CC put it in CC1 Text1
Dec 10, 2007 | Hitachi 50FX20B 50" Rear Projection...
Some channels on my tv have a black screen.
Check that you arent in close caption mode ( usally in the menu)
Aug 06, 2007 | JVC AV-36260 TV
Televison & Video Logo
70 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
