Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit D41 dishwasher problem
Hi, My dishwasher seems to start ok i.e. resets, drains water and then sounds like water is being pumped in. It then stops on no 2 - the scrubbing bush and does nothing. When I open the dishwasher there is no water inside. I've checked the water inlet pipes - all seems fine. Can anyone help? Donna
  • 1 more comment
  • markgoodison Dec 26, 2008
    Please explain how to check the valve?
  • obiw1 May 03, 2009
    We have the same problem and we've had everything checked. All the valves and wiring seem fine, but still it gets stuck. Would it be anything to do with the pcb? Does anyone know how much they cost and where they can be bought from?
    Iona
  • Anonymous Mar 31, 2014
    fitted new bush wqp12-9348 dishwasher and it won't work , checked water and electrical supply and both ok
    New Friend:
Hi I have a indesit di620 dishwasher it's flashing number 2 light and won't finish any cycle it just drains the water In to the waste continuously any have this problem??
Posted on Jul 17, 2013
    Novelist:
  • 159 Answers
You need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Posted on Aug 06, 2007
SOURCE:
How to fix my Indiset d41 dishwasher ? The power button trips out the electrics ! Stopped mid programme , wont drain , still water left in it after it flooded the kitchen . Cant try any other programme as...
You have a component down to earth. The problem isn't the start button. Most likely to be the element, but ciuld be wash or drain pump. Check the element with a resistance meter first, when you find the componant at fault, replace it
Feb 04, 2018 | Indesit 18 in. D41 Slim-Line Free-standing...
Will not start cycles
is it doing the initial pump out then filling with water and stopping b4 the wash cycle? if so it may be that the wash motor has failed(you may hear a buzzing) or the pcb is faulty. if the water does not fill into the base there may be a valve fault of a supply fault. any engineer worth his salt should be able to diagnose this fault on first visit and return with a part so dont expect multi visits.
Jul 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
My dishwasher water is no pumping out
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Mar 16, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 40 slimline dishwasher does not drain completely
heatman101
Jan 05, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 dishwasher, switch it on to program,
if applaince does not start draining then there is a possible fault with the door locking assembly,and the appliance thinks the door is open and this will not allow the appliance to start
Jun 28, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 lights 1 & 2 flashing
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
Dec 21, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit dishwasher.
It sounds like the anti flood switch is activated, lean the dishwasher back at a 45 degree angle. If water comes out the back you have a leak. Stand it up and try it try dishwasher, if it works this comfirms leak, you will need to find where it is coming from.
Dec 03, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 Slimline
HI THERE - I ALSO INHERITED A D41 - I HAVE JUST FOUND - SITE WHERE YOU CAN DOWN LOAD INSTRUCTION MANUAL FOR MANY INDESIT PRODUCTS - I NOW HAVE INSTRUCTION MANUAL FOR MY D41 NICELY PRINTED OUT - SEE www.indesitservice.co.uk hope this helps you too - Helen
Nov 14, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
771 people viewed this question
Top Indesit Dishwashers Experts
Marvin
Marvin
Paul Bade
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
