Question about MTX Thunder 8302 Car Audio Amplifier
My amp was working and now it keeps blowing fuses with no speakers hooked up
  • Daniel Champagne
    Daniel Champagne Aug 05, 2007
    It was working after the other problems which I thought I had resolved but now the above problem
  • 113 Answers
Could be bad mosfets or outputs, needs replace
Posted on Aug 08, 2007
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
MTX 8302 sound just quit on front speakers
hi Dan....Have you had any other service or installs shortly prior to the onset of clipping? In any case, the 8302 has Onboard Thermal Protection which is kicking in due to excessive heat. If you've had this running fine for a period of time, by that I mean at least a month, then we need to focus on why you're suddenly overheating......please update your post with any further information and progress.....good luck my friend
Aug 04, 2007 | MTX Thunder 8302 Car Audio Amplifier
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
How can i hook up a second battery to my MTX 4105d amp
well the best way is keep the amp hooked up how it is now and on your amp there is a + and a - for a cap hook up the negative to the negative for the battery and the positive to a fuse like with a 60 amp fuse then the other end of the fuse link goes to the battery
Aug 04, 2010 | MTX Thunder 4250D Car Audio Amplifier
Red light is on but nothing coming out of the amp
Capital Audio Repair -Tallahassee,Fl 850-339-1130 we repair all namebrands & all models
Mar 16, 2010 | MTX Thunder 8302 Car Audio Amplifier
Sub not working and red light on amp stays on?
the amp is under to much pressure get a bigger 1
Nov 18, 2009 | MTX Thunder 421D Car Audio Amplifier
Feedback issues.
Did you run your power and remote wires the same route as your RCA cables? If you dont run the RCA cables on the opposite side of the power and remote you will get feedback through your speakers. I run my power on the side closest to the battery along with the remote ( passenger in my case) and the RCA cables should be on the opposite side( driver side). They say the power current will create a disturbance in the RCA cables that you would hear as feedback. Hopefully this will help you.
May 28, 2009 | MTX Thunder 8302 Car Audio Amplifier
Sond gone
sounds like an internal problem. first disconnect all spks from amp, then switch on head unit and check if amp turns on (LED ON?) then feel the heatsink, if heatsink gets terribly hot then amp has internal fault. if amp doesnt get hot then try connecting a single working speaker to each channel separately, it may occur that one channel is faulty only. amps can shut down if the speaker/s is faulty as well, check all speakers and spk wires for shorts before taking amp in for repair. cheers
MTX Thunder 8302 Car Audio Amplifier Logo
226 people viewed this question
Top MTX Car Audio & Video Experts
Mike Duncan
Mike Duncan
Philip Armitage
Marvin
Marvin
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
