Tv wont respond
Every time i press ANY button on and of my remotes it turns the T.V. on or off!!!
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
The infrared signal that emits from the remote control is not with right frequency. Check it with fresh batteries. If it do not help you, replace the crystal inside the remote control's circuit board.
Posted on Apr 26, 2013
  • 24 Answers
SOURCE: my dish network remote stop working
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux mode. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with! -Kirstie DISH Network
Posted on Feb 10, 2011
leorcid
  • 281 Answers
SOURCE: RCA TV Remote Malfunction
From your post I understand that the tv is not turning on even if you use the button on tv, if that is the case there is nothing wrong with the remote control, and from the blinking light shows that there is something wrong with the tv. Get it checked by a qualified service guy.
Posted on Jan 25, 2008
  • 5 Answers
SOURCE: Remote not responding
It sounds like the remote may need to be reprogrammed to thetelevision or receiver depending on what specifically is not responding. Thefirst thing to do when having problems with a remote it to replace thebatteries, as that is a common cause. If the remote is not changing your DISHchannels then you would need to address the remote to the receiver. This can bedone by pressing 'System Info' button on the receiver then press the 'SAT'button on the remote once, then press the 'Record' button. If the remote is notturning on the television or working the volume, you would need to address theremote to the television. This can be done by doing a 'power scan'. First holddown the TV button for 6 seconds, press and release the power button, then pressand release the 'channel up' button once per second until the television turnsitself off. Lastly, press the pound button, this will lock in the code for yourTV and the remote should then work.
Posted on Feb 01, 2011
  • 22 Answers
SOURCE: The buttons on my remote
Have you tried replacing the batteries? Do you see any damage on the remote? Have you spilled any liquids on it? If the batteries have been replaced and it does not work, you may want to try reprogramming the remote control. If all that fails it may need replacement.
Posted on May 05, 2011
SOURCE: my samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Posted on Dec 13, 2011
My keyless remote for toyota highlander wont work, how can i reprogram it?
To reprogram remote:
turn ignition on
press and release programming/valet switch three times ( you will hear one chirp from system)
press and release lock button on remote ( system responds with confrimation chirp)
press and release valet switch one time ( two chirps from system)
press and release unlock button on remote (system responds with confirmation chirp)
press and release valet switch one time (three chirps from system)
press and release option button on remote (system responds with confirmation chirp)
turn igntion off
test remote
Oct 05, 2010 | APS20B Prestige Keyless Remote Alarm
Need codes for LG tv from rca remote thank u.
Hi! You can try using these steps for you to program your RCA remote control to your LG TV.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the device does not respond, repeat steps 1-6.
I hope this works for you.
Jul 13, 2010 | RCA Universal Remote Control
Cant program my rca remote for my LG tv don't have code
Hi! You try using these steps for you to program your remote control to your TV.
I hope this helps.
I have a jvc television and bought a universal remote. i dont know the code for the remote. do you know the code?
These are the steps on how to program your Universal Remote Control to your JVC TV even without the list of code.
3. Press and release the TV button you want to set up
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-6.
Jun 14, 2010 | JVC RM-C18G-1H Remote Control
Need code for mitsubishi tv
THE codes for programming RCA Universal Remote Control to a Mitsubishi TV are 006, 011, 014, 019, 022, 027, 041, 056, 061 and 068.
But then if it will not work on these codes you can try these steps for you to be able to program your remote control without the code.
  3. Press and release the TV button you want to set up.The TV button will flash once.
  7. With the TV on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jun 13, 2010 | RCA Universal Remote Control
My remote wont operate my sony TV volume
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Sony RMT-D155A Remote Control
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
Universal remote px-rc1
Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
Mcneileric is right!
Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
Again...
TV onPress and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 secondsPress SET againPress Power to check if the TV turns off^^If nothing happens, press +CHANNEL to search for codePress Power again to check if TV turns off^^If nothing happens, repeat the step between ^^ and ^^If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
Mcneileric, THANK YOU!!!!
Aug 22, 2008 | Radio Shack 15-2142 Remote Control
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
