Question about Garden
What is the spark plug gap on a poulin 3700 chainsaw ?
  • 7,482 Answers
.18-.20
Posted on Apr 26, 2013
muttandjeff
  • 359 Answers
SOURCE: i am trying to find the magneto gap for amakita dcs 340 petrol chainsaw
use a regular post card inserted bet fly wheel and mag close enough
Posted on Dec 05, 2008
steve_lima
  • 181 Answers
SOURCE: Gas chainsaw has no strong spark and wont start
the air gap should be .012", the gap you have it set at is to small.reset the gap and try it again.......hope this helps,let me know........
Posted on Jun 02, 2009
  • 13 Answers
SOURCE: Spark Plug Gap for a Stihls 023 Chainsaw
Here is the manual. The spark plug gap should be .5mm or .02 inches which is 20 thousandths. The spark plug info is on page 55 of the manual under " Ignition System "
http://dl.owneriq.net/d/d23aca42-ef68-46af-adac-3c63327cf0ba.pdf
Posted on Jul 16, 2009
  • 76 Answers
SOURCE: please advise oil/petrol ratio...air gap ...plug
Hi
follow the link there are several manuals there for Echo chain saws
http://lawnandgarden.owneriq.net/manuals/mfg/echo/echo_chainsaw_product_list.html
http://www.echo-usa.com/pdf/documentation/CS300034003450efT1E_060402_1.pdf
on page 4 it says the types of oil and petrol
hope it helps
appreciate some rating form you.
thanks
Posted on Jul 18, 2009
joecoolvette
  • 5660 Answers
SOURCE: I NEED TO KNOW THE SPARK PLUG GAP AND MAGNITO GAP
Spark plug gap is .025
As for the air gap in-between the flywheel, and magneto, I generally start with a piece of notebook paper in-between them.
After the bolts are snugged down, turn the flywheel by hand to spin the paper out.
Posted on Oct 29, 2009
Air gap setting in .ooo
Hi Harold.
Is it the spark plug gap you're looking for?
Typically .025
Here's a link so you can check for your make and model.
https://www.google.ca/#q=chainsaw+spark+plug+gap
Cheers
Feb 02, 2016 | Garden
What is the spark gap for 221 pro 40cc
The gap for all Poulan chainsaws, regardless of the spark plug used, is .025.
Jun 12, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Spark plug gap on husky 350 chainsaw
The plug should gap at 0.5 mm or .020" and be sure to use the proper resister plug. Do not cross reference a plug.
May 25, 2014 | Husqvarna Forest & Garden No.967012396 345...
What is theair gap setting poulan 2150 2.1c i
.025" or .6MM is the spark plug gap I assume air gap is what you were referring to is spark plug?
May 16, 2014 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
What spark plug (make, number) can I get for a Poulan 2025 chainsaw and what gap?
Replace with Champion CJ-7Y or RCJ--7Y spark
plug and tighten securely with a 3/4 inch
socket wrench. Spark plug gap should be
0.025 inches
R stands for resistor on the RCJ-7Y. Either plug will work.
PDF of Owners Manual
If you have other questions about your saw, there is an 800# at the top of PDF.
Hope this helps.
Oct 21, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I Have a Poulin chainsaw with spark and gas. The spark is not as strong as it shoud be, hence I can turn the motor over holding the sparkplug in my hand and feel very little charge from it. I have tried...
I think you should check the gap setting on the magneto and make sure it isclean. Replace mag if output is still weak. Also check all wiring connections to make sure they are clean and tight.
I'm sorry but I don't have many manuals for poulan and you didn't say what model number it is. If you have owners manual it should tell you what the gap is. Good luck and thank you.
Jun 20, 2011 | Poulan Garden
Chainsaw wont start. new plug has a little spark.
The engine case needs to be removed to expose the flywheel and ignition module. Check the module pole gap to the flywheel magnets with a thin business card for a gauge. If the gap is excessive, that can give a weak spark. If the gap appears to be correct, then it is probably time for a new ignition module. Make sure the spark plug is gapped at 0.020" before condemning the module. The spark should be blue and snappy. Check it in a dark area. Hope this helps!
Apr 17, 2010 | Garden
Jul 10, 2009 | Garden
Jun 02, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
