Question about Revolution Mobility Roro Jr., 3 Wheel Scooter
Roro does not go what does it mean when it blinks 7 x's in sequence n than all over again but does not go. Is there a way to fix this
  • 36 Answers
7 is throttle trip Remove battery pack .remove key .charge battery pack then refit ,have a cupper then try with key back in .if this fails you need dealer
Posted on Apr 30, 2013
How to repair HDTV 50 inch TV red light stay on an blink model number is pt-47wx34j how to fix
The set has two common error codes: watch the red light blinking and count the sequence-----3 blinks is most common and is short protection--that one is fairly easy to fix---second most common is 5 blinks which means a short on the 140 volt line--that one is more complex to fix.
Which or neither?
Jun 06, 2012 | Panasonic Televison & Video
The red "on" light is blinking and the TV
a suggestion: unplug set and try to turn on again; if power light blinks does it blink in a sequence?
3 blinks repeated will mean a problem in the Convergence area.
5 blinks repeated will mean a short on the 140 volt line.
These are the two most common error codes.
SD TECH
Aug 31, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Our Mitsubishi projection tv went out one day. When we went to turn it back on all it does is blink the green light for a few seconds and then shuts off. What could it be? Where can we look to see where...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
SD TECH
Aug 09, 2011 | Mitsubishi WS-65807 65" Rear Projection...
MY TV IS NOT COMEING ON IT IS MITSUBISHI
This is NOT a solution but a suggestion:
So you may know what is wrong, if power light (green) comes on and then goes off:
PRESS AND HOLD"device" and "menu" buttons on front of tv for at least 5 seconds and thenrelease both together.
SD TECH
Jun 26, 2011 | Mitsubishi WS-65615 65" TV
The blink sequence is dot,dot...dot,dot then powers off
if you are saying 2 blinks, 2 blinks I can help.
this is short protection and means a fuse and convergence problem.
I have start to finish instructions for this if you are interested.
you can also email me or chat at etower7662001@yahoo.com
Steve
Jun 18, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Was working fine now will not turn on
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
SD TECH
Jun 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
I have a Mitisubishi rear projection tv. When I turn the power on, the power will go off in just 2 or 3 seconds. What is the problem?
HERE IS WHAT YOU DO:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
LET me know what you find and I will tell you what it means and if possible how to fix it.
If this information helped you rate this solution as I do this here for free.
SD TECH
Dec 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Turns itself off after being turned on.
Here is what you do:
SD TECH
Dec 07, 2009 | Mitsubishi WS-48313 48" Rear Projection...
52 inch panasonic projection tv won turn on and flashes what appears to be a diagnostic code?
The most common error codes are when the set does not turn on the power light on the front blinks in a sequence---most common is 3 blinks, a pause and 3 blinks etc
If you have to, unplug the set and try to turn it on again and see what the sequence of blinks is.
Let me know what you find and I will try to tell you what it means.
rate this solution as I do this here for Free.
SD TECH
Nov 27, 2009 | Televison & Video
Service Lights
51 usually means the 250 hr service is overdue .
CPU blinks in a code - is it steady or a sequence ?
Jun 14, 2009 | Garden
Revolution Mobility Roro Jr., 3 Wheel Scooter Logo
52 people viewed this question
Top Revolution Mobility Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Revolution Mobility Health and Beauty Expert? Answer questions, earn points and help others
