Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
Whirlpool diskmaskin felkod f6 e4 - Whirlpool 24 in. ADP5966 Free-standing Dishwasher
Whirlpool dishwasher error code f6e4
F6 error fault code...
This is the Water tap closed. What that means is that the flow meter is not recording water entering the dishwasher, this can be a water tap turned off (suprisingly more common than you'd think, after new flooring or decorating has taken place),water hose kinked or blocked, the dishwasher water soleniod valve defective.
Dec 18, 2013 | Dishwashers
Fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Sep 07, 2012 | Whirlpool Ovens
Whirlpool Accubake Range - error F6 E4 , how do I stop the beeping
Replace the sensor as shown in the F6 code
F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC)
Error Code: E4
Cause: Shorted sensor
Example: Disables cooking in affected oven
Corrective Action: Check sensor
Nov 02, 2010 | KitchenAid KESC300 Electric Kitchen Range
Error code F6-E4
Igoogled this all i could find wea control panel fault nothing for e4
Dec 11, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
F3 E4 Err
HI, i am wondering if you has some power outages? if you did, unplug your oven from the wall for 30 min and the computer will reset it self. It worked for me! hope this helped you.
Jun 03, 2008 | Whirlpool RF262LXS Kitchen Range
Kitchenaid gas range KGSA906PSS
Google kitchenaid error codes...
I have had three ranges and at least five circuit boards so far... they are garbage, if under warranty, call and complain LOUD.
Jan 17, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
1,236 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
