Question about Baumatic B180SS And B60SS (Bundle) Electric Single Oven
Baumatic b180 oven
My oven element has blown (rear one around the fan) and i need to replace, but there also is a small hole in the oven internal caseing, left of the element. Should there be a temperature probe next to the rear element? If so can i have the link to order one. Thanks.
  • bibaness Dec 20, 2009
    My Baumatic oven stopped working. It had a strange graphite heating up smell the day before when the oven was working. Today it switched on and after five minutes made a hissing sound and stopped working
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories. I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe. In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link: http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B Hope that helps! ;)
Posted on Aug 06, 2007
SOURCE:
Why has baumatic B501SS oven covered in light gray coating inside when heated, now not working
It sound like the heating element burned out. Check the element and see if there is a burned spot or blister somewhere along the element. If so the element will need replacing.
May 03, 2014 | Baumatic B180 Electric Single Oven
Electric oven dont work
sounds like the heating element, also check the thermostat
Apr 06, 2010 | Baumatic B180 Electric Single Oven
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Thermastat or element ?
Could be both parts are faulty from symptoms you describe.
The indicator light should not be on if it is in the off position, this would suggest the thermostat is faulty.
On the other hand, if the element is faulty, then obviously, there will be no heat
To be certain if the element is faulty or not, then you need to test the element with a meter.
Jan 20, 2010 | Baumatic B180 Electric Single Oven
I have a Korting fan assisted oven, it
It is without doubt the element that has blown.
It is located at the rear of the oven compartment behind a removeable cover.
Hope this helps solve your problem
Dec 14, 2009 | Baumatic B180 Electric Single Oven
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Jan 17, 2009 | Baumatic B180 Electric Single Oven
Light
easy. unscrew bulb cover then unscrew bulb. switch off at wall first.make sure you use a heat-proof bulb to replace
Apr 22, 2007 | Baumatic B180 Electric Single Oven
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Baumatic B180SS And B60SS (Bundle) Electric Single Oven Logo
578 people viewed this question
Top Baumatic Ovens Experts
Marvin
Marvin
Dennis Boxerman
Lawrence Oravetz
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
