Question about SanDisk Sansa e260 MP3 Player
Load main image failed switch to recovery mode is on my screen and it is black I cant get it to do anything how do you reset it or switch to recovery mode?
  • 3 more comments
  • Anonymous Mar 16, 2008
    load
  • Anonymous Apr 30, 2008
    load main image failed,switch to recovery mode
  • Anonymous Jun 14, 2008
    My screen is black and tells me to switch to recovery mode....what do i do?
  • roggery10 Feb 24, 2009
    tengo un problema con mi sansa e260 un dia al quitarlo del usb se apaga y cuando lo prendo me dice lo siguiente: load main image failed switch to recovery mode. que puedo hacer???? ayudenme por favor soy nuevo en el foro.
    mi email es [email protected]
    ayuda por favor gracias
  • Anonymous Mar 08, 2009
Tengo un problema con mi sansa e260 un dia al quitarlo del usb se apaga y cuando lo prendo me dice lo siguiente: load main image failed switch to recovery mode. que puedo hacer???? ayudenme por favor soy nuevo en el foro mi email es [email protected] ayudame por favror gracias
Posted on Feb 24, 2009
Go to this website. I had the same problem, but after doing this it worked. http://www.anythingbutipod.com/forum/showthread.php?t=11233
Posted on Aug 24, 2007
(( Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. )) When i get to step two, and did what it told me, i get this ( Application failed to read the version details ) What should i do?!?!?!?!
Posted on Aug 10, 2007
SOURCE:
  • 19 Answers
SOURCE: Load main image failed, Switch to recovery mode"
If it still plugs in and works properly, you can try to format it or try to update its firmware with the firmware updater that you can download from sandisk.com and then click on download.
Posted on Jan 24, 2008
SOURCE: "Load main image failed. Switch to Recovery mode"
read this thread!
http://www.anythingbutipod.com/forum/showthread.php?p=63513
Posted on Mar 14, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: SanDisk e260
The volume + method listed below is the recovery method - you can somtimes substitute REC for volume +:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Load main image failed Switch to Recovery mode
Use the Sansa Recovery Tool on the Sandisk website
Posted on Jun 02, 2008
  • 102366 Answers
SOURCE: My Sansa E260 says load main image failed switch
http://www.sandisk.com/sandisk-support/driver-download-wizard
Posted on Jul 09, 2010
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
Black screen that just says "load main image failed Switch to recovery mode"
okay have u tried going in recovery mode, (push power and hold at same time) may it will boot the whole system, if not look out for ROCKBOX (rockbox.org) foe new operating system
Dec 10, 2009 | SanDisk Sansa e250 MP3 Player
Sansa player wont turn on
To get it in recovery mode. Put the Hold switch into the lock position. Then hold REC and Power for about 10 seconds.
You need to hook up your cable after that and you can reset the firmware.
Nov 17, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 load main image failed
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Problem starting
Get the Sansa Recovery Tool from the sandisk website
Jun 28, 2008 | SanDisk Sansa e270 MP3 Player
Jun 01, 2008 | SanDisk Sansa e250 MP3 Player
go to sandisk and go to support there you can find support the recovery software. hope it helps
Jun 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
1,259 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
