Question about Clarion VRX755VD Car DVD Player
VRX755VD "triggered audio mute for cellular telephones"
I accidently grounded the wire for the "triggereed audio mute for cellular telephones" thinking that it was the parking brake wire. i disconnected the wire but now no sound will come out of the speakers. The system powers up and appears to be playing the cd or on the radio, but still no sound. I believe that it is still stuck on mute due to the triggered audio mute. Any suggestions how i can fix this? I already hit the reset button on the unit, but still nothing. thanks...
  • 5 Answers
Well, it sounds like you need a new output IC, which is what produces sound to the speakers.
Posted on Aug 09, 2007
  • Bernard Apr 02, 2012
    What is output IC? Where do you get part? And howl do u replace it?
  • Michael O'Connor
    Michael O'Connor Apr 03, 2012
    svrider01 If your problem is concerning the Clarion VZ400 that is in your "problems" under your profile, try disconnecting the phone interrupt cable and see of that fixes it. Let me know if that helps.
SOURCE:
Wiring diagram from player to dc battery
Here is Alpine's wiring info:
Black: Ground
Yellow : 12v+ Constant
Red: 12v+ Switched
Blue: Electric Antenna Trigger
Blue/White: 12v+ Remote Trigger
Orange: Illumination
Orange/White: Dimmer
Brown: Mute
White: Left Front Speaker +
White/Black: Left Front Speaker -
Gray: Right Front Speaker +
Gray/Black: Right Front Speaker -
Green: Left Rear Speaker +
Green/Black: Left Rear Speaker -
Violet: Right Rear Speaker +
Violet/Black: Right Rear Speaker -
Dec 21, 2013 | Alpine TDA-7563 Cassette Player
I need a wiring diagram for my clarion vrx755vd
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
Mar 14, 2010 | Clarion VRX755VD Car DVD Player
I have a pioneer super tuner3d it has a mute wire where does it hook up to
This is directly from the installation manual from pioneer website for model DEH-P6600
(Yellow/black
If you use a cellular telephone, connect it via the
Audio Mute lead on the cellular telephone. If not,
keep the Audio Mute lead free of any connections.)
Basically, you don't hook it up unles you have a cellular telephone in your vehicle, not a personal cell phone.
Mar 09, 2010 | Pioneer DEH-P6600 CD Player
How do i make my pioneer super tuner 3d 2 unmute? if i try 2 turn the volume up it just keeps sayin mute and i havent been able 2 find a mute button on it any where?
My Pioneer Super Tuner 3 D was working just fine. The face plate was removed by accident while it was operating. Once it was reinstalled the displays all still work but there is no audio any longer.
Sep 25, 2009 | Pioneer Car Audio & Video
Radio: replacing radio,not stock,have adapter connector, when hooked up radio pwrs up,but NO SOUND,somehow in mute,took to the"radio doctor", radio tests fine,& he saw how I had it hooked up, extra...
YOU WILL HAVE TO TRACE THE WIRES OUT, DO U HAVE A SEPERATE AMPLFIER? MANY OF THESE VANS DO, IF SO THAT IS THE PROBLEM.
HERE IS THE WIRING COLOR DIAGRAM FOR YOUR VAN
1998 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/Orange
Right Rear Speaker Negative Wire (-): Blue/White
Aug 06, 2009 | 1998 Dodge Grand Caravan
1991 318is radio is mute
if the radio is constantly on mute then it could be the telephone mute wire on the radio harness. The mute function works when the mute wire is sent to ground so it could be that the cable insulation has rubbed off and now touching a ground (cars body etc)
Jul 09, 2009 | 1999 BMW 318 ti
When i ground my clarion vrx755vd it still says audio only
that is where its suppose to be connected it that you dont have it grounded properly
Apr 08, 2009 | Clarion VRX755VD Car DVD Player
Kenwood Car music system Tel Mute problem
To my knowledge, some Kenwood head units have a wire specifically for this purpose, to mute the stereo in the event of an incoming mobile call. This would be the brown wire. Normally when not connected to a mobile phone, this wire is shielded/covered. It it was inadvertently exposed and touches any metal part, then it would enable the muting. If the wire is covered and not grounding, then an internal fault exists and most likely the trigger inside where the brown wire leads to.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Car Audio & Video
AVIC-D3 ipod connect&dvd
Maybe you telephone mute wire is accidently touched with the frame(grounded). It's the yellow wire with black stripe, check see if it make contact with a ground point. If it does simply tape it up with some electrical tape. Let me know if that help.
Jan 08, 2008 | Pioneer AVIC-D3 Car DVD Player
Wiring problem
Yellow/black
Orange/white
To lighting switch terminal.
Blue/white
To system control terminal of the power amp or
Auto-antenna relay control terminal (max. 300
mA 12 V DC).
Nov 30, 2007 | Pioneer DEH-P3500 CD Player
Clarion VRX755VD Car DVD Player Logo
336 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
