Question about LG DH30 GoldStar Dehumidifier
DH30 Dehumidifier Compressor Does not Operate
Fan and Compressor turns on when plugged in, but compressor kicks off and fan runs for a few minutes until unit shuts off. No power source problem and compressor is not frozen.
  • 2 more comments
  • nebob Nov 26, 2007
    Fan run's for a short time then turs off.
    COMPRESSOR SHUTS OFF AND FAN SHUTS OFF
    A SHORT TIME LATER.
  • Anonymous Mar 17, 2008
    The dehumidifier fan runs for approximately a minute,then shuts off.jumped out sensor located on front of coil, the compressor comes on then coil begins to freeze and shuts down within a few minutes.could this sensor be bad and if so are parts available.
    Part no.LHD30
    serial no.501tagh13151
    I would appreciate a response to this.Thanks
    Jeff Negley
  • johncerams Apr 13, 2008
    unit ran great for 1st spring. plugged it back in and it ran for 40 seconds and shut down. will not come back on.
I just picked one up at a tag sale, seller said it worked sometimes. Seems to have the same problem as yours. I took the time to tweak all of the connections and then re-soldered the control board with no luck. I finally disconnected the humidity control and it worked fine. By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off. Conclusion so far is that the humidity control rheostat is bad.
Note: Now while running the fan runs continuously and the compressor cycles on and off every 10 to 15 minutes. This may to be normal since the unit appears to be doing its job and I'm not sure how it is supposed to run since a purchased it broken.
Posted on May 10, 2008
SOURCE:
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
Have a Goldstar Dehumidifier GHD30. Approximately 2 years old refurbished. The fan will run on the lowest setting but the compressor does not start. When I turn the dial to a higher setting the breaker...
doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
Jul 25, 2011 | LG DH30 GoldStar Dehumidifier
Kenmore dehumidifier 54501: Fan does not work. I
Call sears see if the compressor is under warranty
Sep 01, 2009 | LG DH30 GoldStar Dehumidifier
Lg LHD30 dehumidifier not producing water; fan and compressor both seem to be working
there may be no moisture to collect in the air. if you turn up the dial and the compressor kicks in, all is fine
Jun 24, 2009 | LG DH30 GoldStar Dehumidifier
LG DH30 GoldStar Dehumidifier Logo
1,228 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Gil Shultz
Anthony Ward
Anthony Ward
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
