Question about Symphonic WF-719 19 in. TV/VCR/DVD Combo
Blank and black image; sist. pal-m x ntsc
I am using the equipment in Brazil, where the signal this in the PAL-M, the image is in black color and white it has with deciding, the TV this configured in NTSC has as to modify for the PAL-M
  • 28 Answers
This TV can not be modified from NTSC to PAL.
Posted on Nov 16, 2008
SOURCE:
I bought this tv, more or less 4 years ago, and I'm live in brazil. So, when I got here the Tv was black and white, no color! What's wrong? Can we help me?
Depending on where the set was purchased (USA) it may be NTSC format and Brazil is likely to be different format like PAL or even Seacam---they do make converter boxes that will convert signal from one format to another.
May 01, 2012 | Dell W2306C 23 in. HD-Ready LCD Television
NTSC to PAL question
yes system conversion is you need just change the crystals! buy a palsecam crystal then replace the old crystal.
Dec 24, 2007 | Hitachi M2 Digital Camera
No color TV on my Trutech 7'' LCD TV + DVD under the cabinet model KLV3170
The TV broadcast system in Brazil is PAL-M.
If this TV was bought from the US then the TV will be expecting the NTSC system.
Your other American TV may be a multi standard TV and is able to detect and adapt to your PAL broadcast system. Not all TVs do this.
How do you connect the DVD to the Trutech TV? Is it with a Scart connector? If so then the TV will not be using any broadcast standard at all and that is why it works properly.
Unfortunately if you have searched all the menus and manual instructions without finding a TV system selection, then this TV may never be able to receive TV broadcast in colour.
Nov 24, 2007 | Televison & Video
Hey i just bought an atari 2600 and when i turn it on with the color switch on, it still stais black and white but the tones of the black and white are diferent from the black and white option, can someone...
Is this an NTSC compatible TV? The result you describe is what can happen if you try to use an NTSC Atari on a PAL TV. The color signals are different.
Jun 18, 2011 | Atari 2600 Console
Does Sharp LC-42SB48UT TV support PAL ? if anyone has this TV you can search under the Option Menu to "Select the video signal system compatible with your equipment from the list...
PAL-M is 525 line 29.97 frames per sec, PAL-N is 625 line 50 frames per sec. Most countries (e.g. UK) use PAL B/G/D/K/I which is 625 line 25 frames per sec. PAl-M is used in Brazil, PAL-N is used in Uraguay and Paraguay. Most modern TVs will handle both PAL and NTSC as long as the RGB input is used (via scart or HDMI).
Mar 08, 2011 | Sharp LC32SB28UT 32 in. HDTV LCD
Hy does a colored tv record in black and white on
I suspect that you have the video standard is incorrect. Ensure you are recording in the same format as the signal you recieve. IE: NTSC or PAL. Whatever but they should both be the same. IE: Signal recieved = NTSC Video recorder must be set NTSC as well. Same goes for PAL.
Jan 13, 2010 | Quasar VV-2002 20 in. TV/VCR Combo
I bought an HDTV LCD Sanyo from USA got it with me to Lebanon, when I turn the TV on the picture is so clear but it will not work on the satelite or caple, the picture not clear and has no voice. I need to...
There are currently 3 main television standards used throughout the world:
NTSC - National Television Standards Committee. The oldest existing standard, developed in the USA. First used in 1954. Consists of 525 horizontal lines of display and 60 vertical lines. Sometimes irreverently referred to as "Never Twice the Same Color." Only one type exists, known as NTSC M.
Here is a list of TV STANDAREDS I had for a while and can finally share it with someone. GOOD LUCK!!!! TECHMAN
SECAM - Système électronique pour Couleur avec Mémoire. Developed in France. First used in 1967. A 625-line vertical, 50-line horizontal display. Sometimes referred to by wags as "Something Essentially Contrary to the American Method" or SEcond Colour Always Magenta!" Different types use different video bandwidth and audio carrier specs. Types B and D usually used for VHF; types G, H, and K for UHF; types I, N, M, K1 and L for both VHF/UHF. Different types are generally not compatible.
PAL - Phase Alternating Line. Developed by German engineer Walter Bruch and the German electronic corporation Telefunken. Walter Bruch
patented his invention 1963 and the first commercial application of the PAL system was in August 1967. Also a 625/50-line display and variant of NTSC. Proponents call it "Perfection At Last." Due to the cost of the enormous circuit complexity, critics often refer to it as "Pay A Lot". Different types use different video bandwidth and audio carrier specs. Common types are B, G and H; less common types include D, I, K, N and M. The different types are generally not compatible.
Television Standards by Country
COUNTRY SIGNAL TYPE
AFGHANISTAN PAL B, SECAM B
ALBANIA
PAL B/G
ALGERIA
PAL B/G
ANGOLA PAL I
ANTARCTICA NTSC M
ANTIGUA & BARBUDA
NTSC M
ARGENTINA
PAL N
ARMENIA SECAM D/K
ARUBA
NTSC M
AUSTRALIA
PAL B/G
AUSTRIA
PAL B/G
AZERBAIJAN SECAM D/K
AZORES PAL B
BAHAMAS
NTSC M
BAHRAIN
PAL B/G
BANGLADESH
PAL B
BARBADOS
NTSC M
BELARUS SECAM D/K
BELGIUM
PAL B/H
BELGIUM (ARMED FORCES NETWORK) NTSC M
BELIZE
NTSC M
BENIN SECAM K
BERMUDA
NTSC M
BOLIVIA
NTSC M
BOSNIA/HERZEGOVINA
PAL B/H
BOTSWANA SECAM K, PAL I
BRAZIL
PAL M
BRITISH INDIAN OCEAN TERRITORY
(AF DIEGO GARCIA TV - AFRTS) NTSC M
BRUNEI DARUSSALAM
PAL B
BULGARIA
PAL
BURKINA FASO SECAM K
BURUNDI SECAM K
CAMBODIA
PAL B/G, NTSC M
CAMEROON PAL B/G
CANADA
NTSC M
CANARY ISLANDS
PAL B/G
CENTRAL AFRICAN REPUBLIC SECAM K
CHAD SECAM D
CHILE
NTSC M
CHINA (PEOPLE'S REPUBLIC)
PAL D
COLOMBIA
NTSC M
CONGO (PEOPLE'S REPUBLIC) SECAM K
CONGO, DEM. REP. (ZAIRE)
SECAM K
COOK ISLANDS PAL B
COSTA RICA
NTSC M
COTE D'IVOIRE (IVORY COAST) SECAM K/D
CROATIA
PAL B/H
CUBA
NTSC M
CYPRUS
PAL B/G
CZECH REPUBLIC
PAL B/G (cable), PAL D/K (broadcast)
DENMARK
PAL B/G
DIEGO GARCIA NTSC M
DJIBOUTI SECAM K
DOMINICA
NTSC M
DOMINICAN REPUBLIC
NTSC M
EAST TIMOR
PAL B
EASTER ISLAND PAL B
ECUADOR
NTSC M
EGYPT
PAL B/G, SECAM B/G
EL SALVADOR
NTSC M
EQUITORIAL GUINEA SECAM B
ESTONIA PAL B/G
ETHIOPIA PAL B
FALKLAND ISLANDS (LAS MALVINAS) PAL I
FIJI NTSC M
FINLAND
PAL B/G
FRANCE
SECAM L
FRANCE (FRENCH FORCES TV) SECAM G
GABON SECAM K
GALAPAGOS ISLANDS NTSC M
GAMBIA PAL B
GEORGIA SECAM D/K
GERMANY
PAL B/G
GERMANY (ARMED FORCES TV GERMANY) NTSC M
GHANA
PAL B/G
GIBRALTAR
PAL B/G
GREECE
PAL B/G
GREENLAND
PAL B
GRENADA
NTSC M
GUAM
NTSC M
GUADELOUPE SECAM K
GUATEMALA
NTSC M
GUIANA (FRENCH) SECAM K
GUINEA PAL K
GUYANA NTSC M
HAITI
SECAM
HONDURAS
NTSC M
HONG KONG
PAL I
HUNGARY
PAL K/K
ICELAND
PAL B/G
INDIA
PAL B
INDONESIA
PAL B
IRAN
PAL B/G
IRAQ
PAL
IRELAND, REPUBLIC OF
PAL I
ISLE OF MAN
PAL
ISRAEL
PAL B/G
ITALY
PAL B/G
JAMAICA
NTSC M
JAPAN
NTSC M
JOHNSTONE ISLAND NTSC M
JORDAN
PAL B/G
KAZAKHSTAN SECAM D/K
KENYA
PAL B/G
KOREA (NORTH)
SECAM D, PAL D/K
KOREA (SOUTH)
NTSC M
KUWAIT
PAL B/G
KYRGYZ REPUBLIC SECAM D/K
LAOS PAL B
LATVIA PAL B/G, SECAM D/K
LEBANON
PAL B/G
LESOTHO PAL K
LIBERIA
PAL B/H
LIBYA
PAL B/G
LIECHTENSTEIN
PAL B/G
LITHUANIA PAL B/G, SECAM D/K
LUXEMBOURG
PAL B/G, SECAM L
MACAU PAL I
MACEDONIA PAL B/H
MADAGASCAR SECAM K
MADEIRA PAL B
MALAYSIA
PAL B
MALDIVES PAL B
MALI SECAM K
MALTA
PAL B
MARSHALL ISLANDS NTSC M
MARTINIQUE
SECAM K
MAURITANIA SECAM B
MAURITIUS
SECAM B
MAYOTTE SECAM K
MEXICO
NTSC M
MICRONESIA
NTSC M
MIDWAY ISLAND NTSC M
MOLDOVA (MOLDAVIA) SECAM D/K
MONACO
SECAM L, PAL G
MONGOLIA SECAM D
MONTSERRAT NTSC M
MOROCCO
SECAM B
MOZAMBIQUE PAL B
MYANMAR (BURMA)
NTSC M
NAMIBIA PAL I
NEPAL B
NETHERLANDS
PAL B/G
NETHERLANDS (ARMED FORCES NETWORK) NTSC M
NETHERLANDS ANTILLES NTSC M
NEW CALEDONIA SECAM K
NEW ZEALAND
PAL B/G
NICARAGUA
NTSC M
NIGER SECAM K
NIGERIA
PAL B/G
NORFOLK ISLAND PAL B
NORTH MARIANA ISLANDS NTSC M
NORWAY
PAL B/G
OMAN
PAL B/G
PAKISTAN
PAL B
PALAU NTSC M
PANAMA
NTSC M
PAPUA NEW GUINEA PAL B/G
PARAGUAY PAL N
PERU
NTSC M
PHILIPPINES
NTSC M
POLAND
PAL D/K
POLYNESIA (FRENCH) SECAM K
PORTUGAL
PAL B/G
PUERTO RICO
NTSC M
QATAR
PAL B
REUNION SECAM K
ROMANIA
PAL D/G
RUSSIA
SECAM D/K
ST. KITTS & NEVIS
NTSC M
ST. LUCIA
NTSC M
ST. PIERRE ET MIQUELON SECAM K
ST. VINCENT
NTSC M
SAO TOMé E PRINCIPE PAL B/G
SAMOA, AMERICAN
NTSC
SAUDI ARABIA
SECAM B/G, PAL B
SAMOA NTSC M
SENEGAL
SECAM K
SEYCHELLES PAL B/G
SIERRA LEONE
PAL B/G
SINGAPORE
PAL B/G
SLOVAKIA PAL B/G
SLOVENIA PAL B/H
SOMALIA PAL B/G
SOUTH AFRICA
PAL I
SPAIN
PAL B/G
SRI LANKA PAL
SUDAN
PAL B
SURINAME
NTSC M
SWAZILAND PAL B/G
SWEDEN
PAL B/G
SWITZERLAND
PAL B/G
SYRIA SECAM B, PAL G
TAHITI
SECAM
TAIWAN
NTSC
TAJIKISTAN SECAM D/K
TANZANIA
PAL B
THAILAND
PAL B/M
TOGO
SECAM K
TRINIDAD & TOBAGO
NTSC M
TUNISIA
SECAM B/G
TURKEY
PAL B
TURKMENISTAN SECAM D/K
TURKS & CAICOS ISLANDS NTSC M
UGANDA
PAL B/G
UKRAINE
SECAM D/K
URUGUAY PAL N
UNITED ARAB EMIRATES
PAL B/G
UNITED STATES
NTSC M
UNITED KINGDOM
PAL I
UZBEKISTAN SECAM D/K
VENEZUELA
NTSC M
VIETNAM
NTSC M,SECAM D
VIRGIN ISLANDS (US & BRITISH)
NTSC M
WALLIS & FUTUNA SECAM K
YEMEN
PAL B/NTSC M
YUGOSLAVIA PAL B/G
ZAMBIA
PAL B/G
ZIMBABWE
PAL B/G
Sep 06, 2009 | Televison & Video
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
New Nintendo Wii
check you've got it on the right PAL/NTSC setting.It's very likely the 50/60hz setting. 480i running at 60hz is NTSC resolution although the PAL Wii of course uses the PAL signal. The TV probably tries to interpret the signal as a real NTSC signal because it's 480i 60hz and thus can't handle the colors. There has got to be an option to switch between NTSC and PAL.
Are you using the same SCART socket that you use for your other consoles or a different one? My SCART3 input on my Panasonic telly has two different modes - one which displays in colour, and one which displays in a sort of grainy black n' white. There is a purpose to it but I can't remember what it is. :-)
Anyway, you switch between the two by pushing the AV button and then hitting the colour button which corresponds to SCART3 a few times 'til you reach the correct setting.
It probably isn't that, but... y'know. Sanity check.
Oct 23, 2008 | Nintendo Wii Console
Black and white images
I had the same problem with my Playstion2. I found that the playstion was givin an NTSC video output but the TV was only for PAL. try it on a TV that is PAL if your gamestation is PAL or on an NTSC tv if its NTSC. Does this help?
May 26, 2007 | Microsoft Xbox Console
Symphonic WF-719 19 in. TV/VCR/DVD Combo Logo
91 people viewed this question
Top Symphonic Televison & Video Experts
Steve Allison
Steve Allison
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
