Question about Exercise & Fitness
Pink avon pedometer with personal alarm and light
How do you turn it off? I have lost the instructions leaflet and the display wont turn off.
3 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: reebok B 2 pedometer
1. Reset pedometer by pressing the reset button.
2. Find a long open place and take 20 steps with the pedometer
closed.
3. Check the number of steps the pedometer counted. It should be
between 19 and 21 steps.
4. If the count was not right, try to move the pedometer forward
(toward your belly button) or back (toward your hip) on your
waist.
5. Repeat this until you get the best count of your steps.
6. Once found, place your pedometer in this spot each day.
Posted on Jul 23, 2009
SOURCE: voicezone talking pedometer instructions, turn off alarm
Push both the up and down buttons at the same time. You might have to repeat this two or three times. It will tell you when the alarm is off.
Posted on Jan 03, 2010
Instructions for Eddie Bauer pedometer
How do I reset the Distance Pedometer?
Jan 12, 2014 | MIO Step 1 Pedometer Pink
I have a maxi aid Talking pedometer and can't figure out how to turn the alarm off
You can cycle threw all the Alarm sounds buy pressing the "UP and DOWN" buttons simultaneously until you hear the "Alarm off" voice, also you will see the little "Bell display" above and between the hours and minutes go away.
Sep 14, 2011 | Maxi Aids Talking Pedometer
I have lost the instruction manual how do i change the setting from miles to kilometers
If you have the model, Ped Alarm - PE319, it doesn't have metric units. Correctly, Brunton sells one model programmed for metric and one with Imperial units. The units are fixed, and no conversion information is programmed into the units. The product web site doesn't come up correctly on my browsers: http://www.brunton.com/product.php?id=45. However a FAQ is available at http://www.brunton.com/faq.php . The manuals are also available here, for the Ped Alarm, click on Instruments and look in the list for that model (followed by .PDF).
I wish I could be of more help.
Oct 30, 2010 | Brunton Digital Pedometer with Alarm
Lost the directions need to know how to set all the buttons
Here see if this helps....
http://www.gaiam.com/product/pedometer+fitness+kit+-+intermediate+level.do
How to use the pedometer:
Take out battery insulator pull tab.
Set the metric / imperial system.
  • Press the S5 (Up/Mode) to enter step mode.
  • Press S3 (Set) and hold button for 3 seconds.
  • Press S5 (Up/Mode) to toggle between metric / imperial.
  • Press S3 (Set) to select.
  • Basic operation buttons:
    Time mode
  • The display shows the current time.
  • Press S6 (Down) to toggle 12/24 hour display format. If 12-hour display format is selected, PM times are indicated with a P.
  • To set time: press and hold S3 (Set) to adjust mode. Hour will flash and display.
  • Press S5 (Up/Mode) of S6 (Down) to adjust the flashing digits. Hold the button for fast scrolling. Press S3 (Set) to confirm and move to minute. Adjust the minute.
  • Press S3 (Set) to confirm, and return back to the time mode.
  • Step mode:
  • Press MODE key to enter step mode.
  • The display shows the steps you have dones.
  • Press and hold S2 (CLE) to reset the step count. All information regarding the step counter/distance/calorie will be erased.
  • Distance mode:
  • Press mode to key enter distance mode. It shows the distance traveled.
  • To set personal stride: press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and / or S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to distance mode. Set stride: 30-180CM (12-70 inch).
  • Calorie mode:
  • Press mode key to enter calorie mode.
  • It will show the calories burned.
  • To set personal weight: Press and hold S3 (Set) to adjust mode.
  • Press S5 (Up/Mode) and S6 (Down) to adjust the flashing digits. Hold button for fast scrolling. Press S3 (Set) to confirm, and return back to calorie mode. Set weight: 10-15kg (20-330 lbs.)
  • Measuring your own stride:
  • An individual's stride may vary in length. Input the appropriate length by measuring the distance of 10 steps and dividing by 10 to get your own stride length.
  • How to adjust:
    Motion sensitivity slide switch
  • Attach the unit correctly and walk 100 steps. If the reading is 105 steps or more, slide the Motion sensitivity switch to the left. If the reading is 95 steps or less, slide the motion sensitivity switch to the right.
  • How to wear your pedometer:
  • Your pedometer clips easily and snugly to either side of the hip portion of your pants or shorts. For best results, keep the unit in line with the crease line of your pants.
  • The pedometer must be directly perpendicular to the ground. The pedometer needs to be at a 60 degree angle to the ground. Dragging your feet, walking with sandals or uneven footsteps in a crowded area can affect the accuracy.
  • The pedometer only works when walking, jogging, or walking up/down stairs.
  • How to use the panic alarm:
  • Pull out the panic alarm pin S7 (Panic Alarm) from the unit to trigger the alarm.
  • Press and hold S1 (RES) to stop sound temporarily.
  • Insert the panic alarm pin back into the unit to stop the alarm instantly.
  • Battery replacement:
    Panic alarm and LED Torch battery:
  • Open the battery door by unscrewing the secure screw.
  • Flip out the exhausted battery and replace with two new *CR2016 (3V) batteries. Make sure the polarity is correct. Close battery door and fasten the screws.
  • heatman101
    Oct 02, 2010 | Gaiam Walking Fit Kit Pedometer...
    Hi I've got a Tanita Pedometer - PD724, and have lost the instructions. Have had to put in a new battery, but can't clear the dsplay or re set it . Can anyone help? Clare
    I can not find the instructions, (there are sites that warn not to lose it)
    So lets go with what I think I know.
    Press and hold the Mode button until your display starts flashing.
    Once it does, use your other two buttons for varying the display amounts.
    At least, that is what i would do.
    Also, my wife get sooooo mad at me, but I have every instruction manual for everything i bought somewhere in the house....
    good luck and don't forget to vote!!!
    Sep 28, 2010 | Tanita 3 AXES PEDOMETER (PD724)
    Voicezone talking pedometer instructions, turn off alarm
    Jun 22, 2009 | Exercise & Fitness
    Exercise & Fitness Logo
    85 people viewed this question
    Top Exercise & Fitness Experts
    Howard
    Howard
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
