Question about Adidas Adistar ADP1786 WW Watch for Men
Where can I buy a new Watch strap for my ADP1786
Need a new leather strap. Wheere to find?
I'm sure there's universal straps u can get but original strap keeps the value
Jun 14, 2012 | DG Dolce & Gabbana Cream DW0058 Watch for...
Tip
How to exchange leather straps for almost any watch brand
Most of the people are pretty sure that when their watch leather straps are worn out they have to replace them with new ones, made by exactly the same brand as their watch brand is. This is completely wrong. About 95% of all watch brand models can be fitted with leather straps from any watch strap producer without loosing brands identity. All you have to do is: 1. Release the strap from the watch; 2. Measure the width of the strap where the spring bar (pin) goes through and write it down or memorize it; 3. Undo the buckle/clasp; 4. Measure the width of strap in place where the buckle/clasp was fitted and write it down or memorize it; 5. Measure the length of the strap (both parts together) and write it down or memorize it. Now you have everything you need for strap replacement. Visit any shop selling leather straps or even find it on the internet. You will find thousands of different colours, patterns and leather variations. The choice is yours. Just one thing to remember: The strap you are buying must match all the measurements you took of your original strap. This is not difficult to match, as the watch straps usually are made to global standards. When you have your new strap delivered, just fit it to your watch and undo the buckle/clasp that came with it. Fit your old, original buckle/clasp on to the new strap and you are done. Most watch manufacturers impress, engrave or laser engrave their logos on buckles/clasps, not on the leather straps itself. So, when you fit the original buckle/clasp on brand new strap of different make, it becomes the original strap of the watch you own. And nobody knows that the strap is, for example, from Hong Kong, but watch is from Switzerland (except you, of course} as they look together as one nicely designed piece and the buckle/clasp works as the proof of identity. In case if your watch has some unusually shaped fixing for the strap, this shape can be easily cut in to the strap by modellers scalpel. At the very end I just want to remind to all readers: Watch straps sold under watch brand names are 2-10 times more expensive. In fact - they are not produced by watch manufacturers themselves, but in Italy, Germany, China and Hong Kong and then sent to watch manufacturers. Just because these straps were fitted to the watches and the buckles or clasps were added to them, these straps automatically becomes their brand straps and cost a lot, lot more. Hope it helps to save your hard earned money.
on Jan 10, 2010 | Watches
I want to change the watch strap, mine is brokem
Probably don't need special order band. Most people buy band that is same width. Bands have a collapsible post on each side where they attach to the watch, you just pick a band that fits the width. To change a watch band you have to use something like a razor blade (single edge common to cleaning) to wedge between the metal frame of the watch and the band, then try to get some friction on the post and push it away from the watch and toward the middle of band such that you collapse the post and get it out of one hole that the post is in (2 holes 1 on each side of post) so you can tilt the post out. A new band usually has 2 posts included since it is common to bend the old posts getting them out and hard to just buy those. Put the post in the band, put one end of post into a hole, then tilt and compress with the razor to push post into position, then slide the razor out which allows it to go in the second hole. Now band stays attached.
Jan 10, 2012 | Adidas Adistar ADP1786 WW Watch for Men
I have a Guess watch model W15513G1, the strap has been damaged, where can i buy a new strap?
Go to http://www.guess.eu/Guess/EN/FAQ#/Guess/EN/FAQ%3Fcat%3D8%26qst%3D4/uid%3D700 and click on "watches".
On the left you will see a list of questions and answers. Click on the one talking about watch straps and how to replace them and yo will see a list of contacts, where you should be able to get a new strap.
Mar 10, 2011 | Guess Sport Gents Strap W15513G1 4 Watch...
Cerruti watch strap cannot be changed in any watch specialists in middlesbrough and i am just wondering where i will be able to get it done
You probably will have to send it away to get sorted (make sure you send it insured and very well protected).
You should contact cerruti to see who the repair shop is in the UK, (not sure they have one.)
Failing that you may be able to buy a replacement strap of ebay and have a general watch shop change strap for you.
Or find a jewellers that sell straps, they should have one that fits.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Cerruti 1881 Watch
My strap broke apart from the rubber part. Do I have to replace the whole thing? Do you have it available?
Hi  rmanllo
It seems that you need to buy a new strap for your watch.
You can go to the following link:
http://www.cartier.com/show-me/accessories#/contact-us/contact-us/send-a-message
Give details about your name , email id, country of residence.
Write in the message box that you need to buy a new strap for your Cartier 21 Autoscaph W10147U2 Watch for Women.
They will get in touch with you shortly.
Hope this helps
Regards
TDCL
Jan 29, 2011 | Cartier 21 Autoscaph W10147U2 Watch for...
I need a strap for my watch, because it broke. can anyone please help me?
Just about any watch shop or jeweler will have a nice selection of replacement straps in whatever style you prefer and they will typically install the new strap you buy from them at no extra charge.
Apr 23, 2010 | Calvin Klein k2151.20 Wrist Watch
Where to buy a strap
you get watch straps on ebay or you can go to watch menders or market or jewlers have them
Oct 03, 2009 | Tissot Prs516 T91141731 Watch
Ironman Triathlon Sleek Ladies watch Band problem.
try simple free or a citrus solution often found in household cleaners. js
May 24, 2008 | Watches
Adidas Adistar ADP1786 WW Watch for Men Logo
41 people viewed this question
Top Adidas Watches Experts
Gil Shultz
 Mikey
Mikey
Are you an Adidas Watch Expert? Answer questions, earn points and help others
