Question about True TBB-2G Commercial Refrigerator
Plustron wine cooler - True TBB-2G Commercial Refrigerator
Why would I need a dual zone wine cooler?
The dual zone wine cooler style is ideal for keeping both reds and white wine without having to restore them in two different wine coolers.
Aug 14, 2012 | Furniture
Tip
Benifits of Wine Coolers & Accessories
Wine Coolers are a great choice for many wine enthusiasts. Wine Coolers & Accessories can be placed virtually anywhere in the home and Wine Coolers offer either a single or dual temperature control zone. A wine accessory is generally any equipment that may be used in the storing or serving of wine.
http://www.jilliandistributors.com/products/wine/
on Aug 16, 2016 | Furniture
What is a build-in wine cooler?
A build-in wine cooler is designed to be built into exiting counter and cabinetry. Build in wine cooler includes a front ventilation system which channels the heat forward from the unit, just like any other wine cooler.
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Do I need a wine cooler to store my wines or can I store them in a normal refrigerator?
The purpose of a wine cooler is to store wines at their proper temperatures in a proper manner. Wine coolers are set to higher temperature ranges than other systems simply because wine should not be kept as cool as other beverages.
Jul 31, 2012 | Furniture
What is a single zone wine cooler?
A single zone wine cooler allows you to store only red/white wine correctly. The cooler has only one temperature control and one space for storing your wines.
Where can I find a wine cooler that has 2 or more different temperatures zones?
there is a wide variety of dual zone wine cooler and theirprices range from around $300 up to $3000 and even more, depends on their and manufacturer. I recommend taking a slightly bigger wine cooler thanintended since once you have your wine cooler you start getting more and morewines and you'll end up with no room...just google dual zone wine coolers
May 29, 2012 | Furniture
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Jan 20, 2008 | Haier BC112G Wine Cooler
True TBB-2G Commercial Refrigerator Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
