Question about Watches
Dakota stingray steel watch remove link - Watches
  • 51 Answers
SOURCE: how to adjust watch band on relic steel watch
OK basically there must be an element that you can push out in the direction of the arrow. Either there is a very thin pin (like a needle) that you can push out with a blunt sewing needle (break the tip), or there is a more sophisticated system as it is shown under the following link:
How to remove links from a watch strap
Cheers
Critter
Posted on Dec 26, 2008
  • 51 Answers
SOURCE: Watch band sizing
OK, I make an attempt:
I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
You can push it out with a blunt sewing needle (break off the tip).
Remove links on both sides of the watch when resizing it.
Hope that helps.
Critter
Posted on Dec 27, 2008
escapement
  • 2334 Answers
SOURCE: How do I shorten watch bracelet?
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 21, 2009
escapement
  • 2334 Answers
SOURCE: how do I adjust band on a guess g95290g guess steel mens watch ?
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
Job done!
Posted on Feb 16, 2009
dmbgo
  • 58 Answers
SOURCE: How do I remove links from stainless steel
The band has pins in it which can be removed by tapping them
Posted on Jun 22, 2009
I lost my Dakota Torch REQ SOS with solid cover/shield. I am trying to find another. I have the charger for it.
Here's a link directly to the Dakota website for this particular brand of watch:
https://dakota.webfeatsecurity.com/watches.aspx?sr=t&Series=25
I looked briefly on E-bay and only saw one available auction for this type of watch, here's the link (it's shortened because E-bay links are huuuuge)
http://goo.gl/gpqq9
May 02, 2011 | Dakota REQ Torch LED Light & Watch
Tip
DAKOTA watch instructions.
Follow this link and download instructions for DAKOTA WATCH COMPANY watches: http://www.buydakotawatches.com/Instructions.aspx
on Mar 15, 2010 | Watches
What about the date how do i change that
Browse through My Tips and Tricks. There you will find manuals (links) for Dakota watches.
Feb 26, 2011 | Dakota Watch Company Radio Controlled...
How do I remove a steel link from a Movado wristband 800 series?
mcdevito75 here, Special tools neede to remove links, Best Bet look for a small watch repair shop in your area, and hold onto those links once removed as you may need them again in the future.
Oct 16, 2010 | Movado 800 Performance watch
Remove links
  • Wrap the watch band around your wrist to determine how many links need to be removed for the watch to fit properly.
  • 2 Place the watch face-down on a flat surface.
  • 3 Look on the back of the watch band. You will find an arrow that indicates which direction you should push the pins to remove the links.
  • Find the point at which the extra links need to be removed for your watch to fit your wrist. Using a 1 mm flathead screwdriver (or the edge of one side of a pair of tweezers), push the pins in the direction indicated by the arrows.
  • Finish removing the pins with your pliers.
  • Keep the extra links in case you ever need extra room on your watch band.
  • For further assistance, check out the link:
    http://www.pulsarwatches.com/home2.asp#FAQ
    Aug 17, 2010 | Pulsar Men's Stainless Steel Bracelet...
    How do you remove links from the subaqua venom
    Find how to remove or add links here: Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524.
    Apr 25, 2010 | Invicta Reserve Subaqua Venom Swiss Quartz...
    Link removal from band
    if you don't have the necessary tools or knowledge then your best bet is to take it in and have a professional remove the link(s) for you. It all depends but sometimes if you take it to Macy's or Neiman's they will do it for free.
    May 23, 2009 | Bulova Watch
    Watch band sizing
    Hope that helps.
    Critter
    Dec 26, 2008 | DKNY 1009 Wrist Watch
    I need to remove 2 links on my pulsar analogue watch.
    You have to drive out the pins from bracelet.
    Split end of the pin must come out first.
    Use blunt steel needle as a driving pin and a small hammer.
    Dec 14, 2008 | Watches
    Watches Logo
    71 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
