Question about Acer Aspire One D257 Netbook
Enter bios setup - Acer Aspire One D257 Netbook
    New Friend:
  • 77 Answers
You need to start tapping F2 as soon as you've pressed the power button.
My YouTube
Live Tech Support
Posted on Apr 26, 2013
How to change to a different date in advanced booting options
To change your system date through Advanced Booting options, you first need to enter BIOS setup menu of your system. To enter BIOS setup menu and to change your system date, you can follow the instructions below:
1.Boot your system and enter BIOS setup menu using the designated key. Though the key to enter BIOS may vary depending upon the computer manufacturer, usually keys like Delete, F12, F10, and F2 are designated to enable a user to enter BIOS setup. To know how to identify the key your system is designated to enter BIOS setup, you can refer to the image under "Method 1 of 3: Enter the BIOS" section on the following webpage:
Important: Following link is of a third-party website. We recommend you to update your security software thoroughly before clicking on the link.
http://www.wikihow.com/Change-Computer-BIOS-Settings
2.As soon as you identify the BIOS setup key, strike it rapidly and repeatedly (while the booting is on) till the time you enter BIOS setup menu. You may get just a few seconds to do this. If you are not able to enter BIOS setup menu by pressing the key repeatedly, reboot your system and follow the same steps again to enter BIOS setup menu.
Note: BIOS menu do not support mouse input. Hence, you will have to navigate through the menu using the arrow keys on your keyboard.
3.Once you enter BIOS setup menu, you can change the date of your system by going to "System Date" option. This option is generally located in the "Main" section of the menu.
Important: The layout of BIOS menu varies from manufacturer to manufacturer but most of them share a few common settings. If you are not able to detect "System Date" option in the "Main" section of the menu, you may need to look into other sections to locate the option.
To get a pictorial explanation of the above steps, you can refer to the following link:
Hope this will resolve your issue.
GuruAid.com
Aug 09, 2014 | Dell Microsoft Windows XP Home Edition
Hp8470 how to enter in bios
You asked this in the Mac Laptops area.
However,
To access the BIOS Setup, turn on the computer and repeatedly press the esc key to enter the Startup Menu, and then press the F10 key to enter the BIOS setup utility.
Figure 1: Example - BIOS Setup Utility
c02258786.gifThe BIOS Setup window consists of options for Security, System Configuration, and Diagnostics.
All the best to you,
Kerry
May 27, 2014 | Computers & Internet
Reset the BIOS on a Compaq server 740 jumpers settings
Don,t do that insatead:
Entering the BIOS Setup menu Entering the BIOS Setup menu requires pressing a specific key at a specific time. If you fail to enter the Setup menu on your first try, repeat the following steps until you are successful:
  1. Close all applications that are currently running and restart the computer by clicking Start , Shut Down , Restart the Computer , and then OK .
  2. When the red Compaq logo or blue HP logo screen appears, press the F10 key on the keyboard to enter the Setup menu.
NOTE: An alternate to the above steps, especially if the logo screen disappears too quickly to enter BIOS, is to shut down (turn off) the computer. Wait 30 seconds, turn the power on and press F10 or F1 at the logo screen. Reloading the default settings Complete the following steps to reload the factory installed BIOS Setup settings:
  1. In the BIOS Setup utility, select the Exit tab.
  2. Select Load Setup Defaults .
  3. Select Save Changes and Exit (pressing F5 and the Enter key will also load the Setup Defaults).
  4. Press Esc and then Enter to exit Setup.
Nov 13, 2010 | Computers & Internet
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
Entering bios setup
Occasionally, most computer owners will need to access BIOS on their computers in order to change or update the computer's most basic operations; such as memory and boot order.
Different computer manufacturers will have you press different buttons to access BIOS depending on the model you have. For example, on my laptop, I press F12 to enter the BIOS setup utility.
Here's how to figure out how to enter your computers BIOS setup utility. 1
Turn your computer on or shut it down and restart it if it is already on.
  • Step 2 As soon as the computer starts up, watch for a message that informs you about which button you will need to push in order to enter setup, aka BIOS.
  • Step 3 The opportunity to press the correct key to enter BIOS passes by quickly, so you need to find that key and press it before the computer moves on to the next stage of booting. If you miss your chance, just restart the computer and try again.
    You can always access BIOS, even on computers that dont have an operating system installed. This is because BIOS is part of your computer's motherboard hardware and has nothing to do with Windows, Linux or whatever operating system you may be using.
  • Dec 02, 2009 | Alienware PC Systems M7700 Notebook
    Apple mac book : how to enter the bios setup
    When you power up the computer press F2 or "del" or F5 or F12 or TAB key to enter in bios.
    Thanks for using fixya.
    Please rate this solution if it helps you.
    Jul 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
    Lost pass word
    How to enter the BIOS or CMOS setup.
    Reasoning: IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
    Solution: Because of the wide variety of computer manufacturers and BIOS manufacturers over the evolution of computers, there have been numerous different ways to enter the BIOS or CMOS Setup. Below is a listing of the majority of these methods as well as other recommendations for entering the BIOS setup.
    Notice: If you are unable to get into the BIOS or CMOS setup because of a password please see document CH000235.
    New computers Thankfully, computers that have been manufactured in the last few years will allow you to enter the CMOS by pressing one of the below five keys during the boot.
    A user will know when to press this key when they see a message similar to the below example as the computer is booting. Some older computers may also display a flashing block to indicate when to press the F1 or F2 keys.
    Press <F2> to enter BIOS setup
    Tip: If your computer is a new computer and you are unsure of what key to press when the computer is booting, try pressing and holding any key on the keyboard. This will cause a stuck key error, which may allow you to enter the BIOS setup.
    Or you can try this:
    Click Start
    Click Control Panel
    Click User Account
    Click on : Computer Administrator
    Dec 04, 2007 | HP Pavillion ZV6000 Notebook
    Lost password
    Or you can do this:
    Click on Start
    Click on Control Panel
    Click on User Account
    Hope this gets ya back on line, Good Luck.
    Merry Christmas.
    I lost password
    Can go to :
    Start
    control panel
    user account
    Hope this gets ya back on line.Good Luck
    OPEN PASSWORD BIOS
    How to enter the BIOS or CMOS setup. Reasoning: IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
    Should get ya back on line , Good Luck
    Dec 01, 2007 | Fujitsu LifeBook C4135 Notebook
    Acer Aspire One D257 Netbook Logo
    43 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
