Question about Kirby Ultimate G Bagged Upright Vacuum
GREEN LIGHT AND MOTOR
The green light blinks when in use and there is a terrible smell coming from the motor.
    Problem Solver:
  • 11 Answers
The green light is an indicator that your brush is rolling smoothly. If it starts to flicker and you smell something that smells like rubber burning you need to do a couple things; one is remove the roller and clean off all of the hair, string, etc. Next you want to replace your belt. Just because the roller isn't turning doesn't mean the motor and the belt aren't either. If your roller gets jammed your belt will continue to spin and it will eventually wear down in one spot and break. Replace the belt, clean the roller and your should be fine.
Posted on May 29, 2013
Vacuum motor noise and smell
If the ball was stuck and you sucked water into the motor it could cause it to smell like it's burning if it ruined the motor
Jan 10, 2014 | Shop Vac Vacuums
Green light mean
The green light blinking means the belt so slipping. The green light being off means the brush is not spinning at all. The belt needs to be replaced at least twice per year for proper agitation.
Jan 04, 2014 | Kirby Vacuums
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
Apr 20, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
Dyson DC29 smell since new
An electrical smell means trouble and can be dangerous. I would take it in for warranty service.
Sep 25, 2017 | Dyson DC29 Allergy Bagless Canister...
The motor in the Kenmore canister started smelling like wire burning and then made terrible noise. I ordered the exact replacement motor and swapped them. Installed the same way the original came out, ran...
Actually there not supposed to burn up. I have read some reviews on that model Kenmore and it seems it is plagued by electrical problems.
I would definitely contact Sears customer service.
Sorry I couldn't be of more help.
Handie Andie
Mar 30, 2011 | Kenmore 25512/ 25513 Progressive Canister...
With vacuum on but not using, motor began to load up--whine began to rise--then sudden free flow and terrible smell emitted...thought the bag had failed and a shot of dog hair and dust reached the motor,...
This sounds like your motor going. If it winds up then down it could need new motor brushes or a new motor. Also, if the smell is kind of rubbery it could simply be the powere nozzle belt. Hope this helps, Chris
Feb 21, 2011 | Kenmore 27514 Bagged Canister Vacuum
The CV750 stopped working. It will come on sometimes but most of time it will not work. I installed new bag and cleaned filter. Green light on side of unit is on. Switch on side of unit will not make it...
The motor may have a sticking brush or a dead commutator segment. Turn off power to the unit to check for sticking brushes. Reapply power, does it now run? If not, shut it off, physically turn the motor a few degrees, and reapply power. If it still doesn't run, look for loose wiring around the motor. If it does run, replace the motor armature or the entire motor if the armature is not available as a separate part.
Oct 18, 2009 | Broan-NuTone CV750 Central Vacuum
The motor is makng a terrible noise - smells like it is burning -how do I check to see if it is a belt?
There are no belts on the SteamVac series. If you are smelling anything, it is nearly positive you have a vacuum motor problem.
Aug 26, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Motor or pump problem?
my guess is you burned out the motor. go to thehooverstore site. look for your machine. they have a parts list for just about any hoover made.
Sep 07, 2007 | Hoover F6020-900 SteamVac Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
408 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
