Question about Weller 8200 Soldering Gun
TIPS BURN OUT
My Weller 8200 soldering gun is over 30 years old. Lately, the tips erode, then burn through is a very short time. I tin the tips regularly. The gun's case has been broken & repaired several times & I have resoldered the connections of the windings to the switch several times. I am using Radio Shack tips because they are low cost-$3 for 2 tips vs. $7 at for 1 at a hardware store. Should I continue to keep this old gun or is there a fix?
  • 1 more comment
  • blithespi323 Sep 08, 2013
    I have the problem (after buying a new model 8200soldering gun). I switched from no-lead rosin-core plumbingsolder to 40/60 tin/lead rosin core solder. No more eroded tips! And the solder is a lot easier to work with. I also began making my own tips from # 10 copper wire. I hammer it to a square crosssection & cut it ot length. The hammering hardens the copper; After bending to shape, I file a flat on the tip for better contact. works great.
    Sorry, I meant to say "I have the SOLUTION".
  • blithespi323 Sep 23, 2013
    Switch to 40%tin/60% lead, rosin-core electrical solder. easier to work with & tips won't burn out.
That fixed it.Thanks.
Posted on Aug 14, 2015
  • 2,113 Answers
It's better to get a soldering station instead.
Posted on Oct 21, 2013
2 Suggested Answers
brianwhite72
  • 12 Answers
SOURCE: I have a older weller
Do NOT attempt to tap out or enlarge the threads. Weller uses special nuts, you can buy a new tip WITH replacement nuts. If you buy the new tip without nuts, you are supposed to bend the two ends 90 degrees, so they fit into the holes in the two cylinders. The tips which are iron-plated will last longer.
Posted on Mar 14, 2012
Wont heat enough to solder
Hello, does your solder iron --Weller- humming? Also, is the solder tips the right tips for you Weller woldering gun? Are the tips tightened on the end of the solder gun prongs?
Well, if it is humming there is internal short in the windings inside of the gun. Don't mess with. Recyle it by taking the copper, brass, aluminum, and other metal out. Now, if it is not humming.
Make sure you have right tips, make sure that the tip is tightened in the soldering gun prongs.
The working principal of these soldering guns is that they work on low voltage and very high current. The current is regulated to keep the tip from burning into. Just enough current to heat the tipe to a certain temperature.. It can shock you but there not enough voltage with current but it will hurt. and could burn you. Be careful and lots of luck...GB...stewbison
Aug 04, 2011 | Weller Standard Tip: 7200
Is the weller 8200 comparable to the "Old Weller
Hello, your Weller 8200 soldering gun is rated at 140 or 160/100 watts. While the junior was about 70 watts. Go to this web site for parts: www.e-sonic.com/aboutus/cat/S/soldering%206.pdf GB...stewbison
Apr 23, 2011 | Weller Welding Tools
I have a old modal 8200.140/100 watts. tip will get hot enough to melt the solder if you touch the tip with the solder.but will not get the wire(18 Gauge} hot enough to melt the solder.
Hello, does your soldering gun humm? If it humms then recycle the parts. There is short across the winding which causing the humm. If not, then make the you have right soldering tip for your Weller gun. Also make sure there is good tight connect on the solder tips with the barrel screws.
It could be a faulty two way trigger switch with internal diac controller. You can order switches from this web site: www.e-sonic.com/aboutus/cat/S/soldering%206.pdf GB...stewbison
Feb 13, 2011 | Weller 8200 Soldering Gun
Weller 8200 series soldering gun sometimes fails to heat; tightening screws and/or gently spreading arms often helps. Is there a permanent fix?
There is constant maintenance needed to keep soldering, the key ones are the tip fastening nuts, and the tip itself. The tip eventually needs sanding and immediate retinning, Clean with damp rag during and after each soldering event, and heavily re tin at end of event.
Sep 14, 2010 | Weller Welding Tools
Need to know where I can get tips for a 8200 gun.
Sears Hardware carries Weller and and has tips for the 8200 Weller Soldering Gun, I just swa them yesterday at Sears Hardware.
May 21, 2010 | Weller 8200 Soldering Gun
Weller soldering gun replacement light bulbs
that takes a common 6volt screw in type bulb you can buy at most radio shacks or parts stores
Jan 22, 2010 | Weller 8200 Soldering Gun
Weller D550 fried brand new tip
are you sure you bought the H.D. tip this is the big gun
Jul 12, 2009 | RTO Weller D550 Soldering Gun
Replacing tip
i have an old 8200 and i just bend the ends of the replacement tip, then i just tighten the bolts. that is how the tip was on the when i bought the 8200. cheers
Nov 07, 2008 | Weller 8200 Soldering Gun
Weller 8200 Soldering Gun Logo
935 people viewed this question
Top Weller Welding Tools Experts
Robert McClure
Lawrence Oravetz
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
