Home | Philips | 30PF9946 30 in. HDTV-Ready Plasma Television | I have a Philips 30P...
Philips 30PF9946 30 in. HDTV-Ready Plasma Television
Problem for Philips 30PF9946 30 in. HDTV-Ready Plasma Television
I have a Philips 30PF9946D/37 no picture
By g00dfugly on Mar 13, 2009
Chassis LC4.6UAA
When turned on I get a flash across the screen within five seconds followed by a blank screen, sound is good. I have the following votages on the PSB 3104 313 60095, cn1307 pins by # 1-35v, 2-18v, 3-15v, 4-gd. cn1304 1-13v, 2-13v, 3-gd. cn1309 1-0v, 2-0v, 3-gd.? cn1306 1- across 2-176v. cn1305 1-5v, 2-5v, 3-gd. cnIM02 1-0v, 2-0v, 3-19, 4-19v, 5-38v, 6-38v, 7-19v, my guess on pin 1 & 2 both are gd. "grounds?" This is my daughters TV so I have it just resting on my dinning room table with no cable connected to it but there is sound coming from the speakers, a hissing noise. If it is the power supply which Is my guess can I repair it with a cap or transformer? Thanks for your help in this, GOD BLESS. Richie B
Same Problem
May 23, 2009
-   philips 30pf9946 black screen problem what is the solution to this-   Guest
Best Solution
posted on Mar 19, 2009
Very Helpful)
W2ICA
Rank: Master
Rating: 92%, 3 votes
what you have is a bad inverter transformer on the inverter board. I nashed my teeth on this problem for a long time because no diagram is avail. Here's the fix for you:
Remove the invertor board. Take an Ohm meter and measure the outer 4 legs of each transformer. Between pins 1 and 4 (side with the white dot near leg 1) you should read .3 ohms. This side is usually good. Between pins 5 and 8 you should read approx 1.8 to 1.9Kohms. ANYTHING above that is a defective transformer. I'm sorry I do not have the part number for this, I've just been using an old board from a set with a cracked panel. If I can find a part number I will try to post. You can try Encompass parts on the web, they may be able to supply part number and transformer with location number.
Rick
W2ICA
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 10, 2009
Not Rated)
jibb
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem and after testing all the legs on the transformers I accidently created a groun dwith one of the lead from my multimeter. I procede to test the the ground on the transformer board and to my surprise one was missing. I created a ground by grounding the ground from the transformer board the the chassis of the tv. This was 3 or 4 mths ago and it still is kicking. This was my problem.
Was this helpful?
Yes
No
Popular Solutions for Philips 30PF9946 30 in.
Questions and Unsolved Problems for Philips 30PF9946 30 in.
Do you recommend Philips 30PF9946 30 in. HDTV-Ready Plasma Television?
Answer
Answer
When I am in the user menu, I acannot change or even see the tint adjuster and a couple of the... (More)
Answer
just recently purchased a sharp lcd television i am having a problem connecting it to my durabrand... (More)
Answer
trying to get owners manual for vimax 32 plasma tv
Answer
Have you fixed it or gotten rid of it yet? Because if not, I have a solution for you. I had the... (More)
Answer
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 30PF9946 30 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
