Question about Sylvania 15 Amp Lamp and Appliance Timer #SA100
Sylvania sa011 timer instructions - Sylvania 15 Amp Lamp and Appliance Timer #SA100
Need instructions to program noma timer 052-8873-0
Copy following link, and scroll down and find same-similar timer, then click on manual and follow instructions in manual, then save manual to your computer, or open manual and add to your homescreen on phone or ipad, then when needed again search phone or ipad for manual or .pdf.
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
Gene
Dec 09, 2013 | Hardware & Accessories
We have an indoor light switch timer and it is going on and off all the time. How do I reset it so that there is no program on it? or just reset the program?
Timer is not identified. You posted under Sylvania timer:
Open following link for instruction manual for re-programming timer.
Problem is not clear.
Do you want to permanently override timer?
Most in-wall timers have override button, but the timing programming resumes at next set point.
When you re-program timer, it lets you set on and off times, but does not let you convert the timer to an ordinary on-off switch.
There is 1 type of timer that has timing function, PLUS optional ordinary on-off capability: Intermatic KM series, Tork 701, Woods 59017, GE15070
http://waterheatertimer.org/Programmable.html#15070
To replace the timer with ordinary on-off switch:
Buy on-off switch at hardware store. Switch will have 2 brass-colored screws and 1 green-colored screw.
Turn off power.
Remove timer wires, but note 1) which wire connected to timer red-or-blue wire and 2) which wire connected to timer black wire.
These two wires will connect to different brass colored screw on new switch.
Jun 30, 2011 | Sylvania Hardware & Accessories
I need the steps for setting the timer function
Link shows the Sylvania indoor timers
http://www.hardwareinnovations.com/prodshelf.asp?dept_id=1007
Click on photo of your timer
Next page opens
Click on the word 'manual' to open a copy of your manual
If you have the AS140, the link below goes to that manual
http://www.hardwareinnovations.com/pdf/SA_130_IB58572_02.pdf
The timer comes with a replaceable battery.
The battery lets you program the timer before plugging timer into wall.
If you need help with instructions in the manual, answer back and I will help.
Oct 24, 2010 | Sylvania 15 Amp Zip Set Digital Lamp and...
SYLVANIA DIGITAL WALL SWITCH TIMER SA 170. NO DIRECTIONS AS TO HOW TO PROGRAM THIS DEVICE. WANT TO TO BE ABLE TO SET SPECIFICI TIME FOR OUTSIDE EAVE LIGHTS TO COME ON AND GO OFF.
Manual at Hardware Innovations Click manual link to right of product photo
Sylvania SA170 manual shows that timer can automatically turn on lights at sunset time, just enter your phone area code: Timer has to wired first and power on. Manual has long list of instructions starting on page 2.
How to wire timer:
SA170 replaces on-off wall switch that has 2 wires + ground
Timer has 3 wires + no ground wire
Wires that come off switch connect to Timer Blue & Black wires
Timer white wire connects with other white wires in box - if you do not have other white wires, connect to bare ground
If timer doesn't work, switch Blue and Black wires
Oct 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
Woods Digital Timer TD 2200
See this website for links to instruction sheets in PDF format for Woods US timers:
http://www.woods.com/us-timer-instructions.asp
Mar 25, 2008 | Sylvania SA130 Digital Lamp Timer
Sylvania 15 Amp Lamp and Appliance Timer #SA100 Logo
56 people viewed this question
Top Sylvania Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Sylvania Hardware and Accessory Expert? Answer questions, earn points and help others
