Question about Grohe Plumbing
How to remove the lever handle Seabury 18732 lavy faucet
  • 3 Answers
SOURCE: price pfister faucet handle drops and turns off.
Re the 'falling handle' issue, I think you misunderstood the problem, jgwhomeequip. Unfortunately for me I bought *two* similar Price Pfister faucets and both had the same problem - the water wouldn't stay on and the handle just wouldn't stay up.
I took mine apart looking for something to adjust, fruitlessly. Put it back together and have lived with it like that for ~2 years.
Finally I decided to not be a knucklehead any longer and call the manufacturer. Once I got through to their rep (on a Saturday no less!) she helped me identify the model I had (a 533-50SS, just FYI), and asked me 'what finish'? I replied 'stainless steel' and she promptly replied, 'I'm going to mail you out new lighter handles to replace the ones you have'.
Brilliant! Gold star for PP for standing behind their product well past the warranty for what was apparently a common problem. Replacing the handle will take about 10 seconds per faucet.
I only wish I had got of my a$$ and called them 2 years ago.
1-800-PFAUCET (1-800-732-8238)
Consumer Service Department:
7:30am to 4:00pm PST, Mon-Sat
Fax: 1-800-713-7080
Hope that's helpful to somebody.
Posted on Apr 04, 2009
  • 5 Answers
SOURCE: cannot figure out how to take apart the lever and
There should be a set screw on the back end or bottom of the handle.
Posted on Aug 25, 2009
  • 3 Answers
SOURCE: Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Posted on Jan 01, 2010
  • 1015 Answers
SOURCE: My kitchen faucet is a
It may just be that you need a new cartridge. If you can replace cartridge without to much problem I would do that. Depending on your water quality the cartridge may be very hard to remove on a faucet that old. Also if the handle actuating hole is worn very much you may have to replace it also. By the time you buy parts you may have half or more of the price of new faucet, I would recommend that you replace faucet. Hope this helps. Thanks
Posted on Nov 17, 2010
  • 83 Answers
SOURCE: Kohler Finial K-310 Widespread Lavatory
should be able to turn the bottom piece under handle and it comes off along with handle..dont think theres a little "cap" that comes off at top of handle..but mite try prying it off it just has an o ring holding it in place and screw will be under that
Posted on Nov 25, 2010
Seabury installation manual
Go to Lowe's and see if they will allow you to copy one. A plumbing supply, that sells that brand may also have one to give you.
May 11, 2014 | Grohe Seabury Widespread Bathroom Faucet...
Tip
How to remove Glacier Bay Lever Kitchen Faucet Handles
To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
I can not get the handles off. there are no screws
There is either a screw under a cap from the top or a set screw from the side. Looked at about 200 Grohe diagrams and they all have that arrangement.
Aug 07, 2012 | Grohe Seabury Widespread Lavatory Faucet...
I can not take the handle off of my shower valve to get to the cartridge. i have a seabury grohe shower valve.
There is usually a set screw near the base of the handle that holds the handle on the valve stem if the handle is metal. if it is acrylic then there is a plastic cover that hides a screw which fastens it to the valve stem.
Nov 24, 2010 | Grohe Plumbing
Hot water handle hard to turn.
depends on which model faucet you have...
some handles are removed by removing a screw in the top of the handle hidden under a small decoritive cap
some handles are removed be removing a set screw using an allen wrench in the side of the handle usually under a small rubber plug
Jul 07, 2010 | Kohler K-16102-4-AF Revival Widespread...
Leaky faucet
From the sounds of it. It is time to call in a Pro. Be sure to check references. I hope all goes well.
May 26, 2010 | Grohe Seabury Roman Tub Faucet with...
How to remove single lever handle does it require a spceial tool, because an allen wrech doesn't work
Most faucets have allen screws holding handle on or it may be recessed back in handle or if it is striped out may need to get a bolt extracter you can get them at hardware store pretty cheap.
Apr 25, 2010 | Price Pfister Single Lever Handle Faucet...
Can't remove lever hadle to replace cartridge. no set screw how do i remove the handle? i think it is a moticello. if not it has 4" centers with lever handle and it cost about $90.00 3 years ago.
the lever handle on that faucet is two pieces, it seperates at the top of the big round part. Hold the big round part with one hand and unscrew the smaller round piece out of the top of it. You must turn the small round part, turning the handle will do no good.
Mar 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Installed a new price pfister two knob kitchen faucet and the cold faucet turns off backwards. How do I make it shut off in the right direction ? Thanks !
you will have to remove the faucets and turn the base around, that is the only way to make it right you installed them backwards
Jun 28, 2009 | Price Pfister Savannah Two-Handle Kitchen...
Single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Plumbing Logo
74 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
