Aeg pumpen 88739 update
C2
2 Suggested Answers
zeusfaber
  • 247 Answers
SOURCE: Problem C2 with AEG Lavamat 86741
Find the drain pump (on most front loaders, it's at the bottom of the machine at the front - often with an access hatch).
Open it up (you may want to tip the machine backwards and put a basin underneath to catch the water - and be prepared to close up again if the basin gets full before the machine is fully drained). Check that the pump impeller isn't jammed with a collection of old coins.
My next move would usually be to set the machine going in a part of the cycle where the drain pump is supposed to be running, and to give the impeller a quick flip with my fingertips (taking great care to avoid injury). If the pump doesn't run until you flick it, but then starts, this is a sure sign that you need to replace the pump motor - a quick, cheap and easy fix.
If the pump starts by itself, the the problem is more likely to be one of blocked hoses.
If the pump won't start at all, either by itself or when you flick the impeller, you need to check whether the pump is getting electricity. Do this by disconnecting the machine from the mains, connecting a voltmeter across the two terminals on the pump, then switching back on and selecting a bit of the cycle where the pump is meant to run. If you see mains voltage, then again you want to change the pump motor. If you don't, then check all the associated wiring before starting to look at the main timer. Disconnect the power before removing the voltmeter connections.
A.
Posted on Mar 05, 2008
My AEG Lavamat 41280 update gives an E90. How to reset my machine
Hallo, my AEG lavamat 41280 update gives E20 warning, what should I do? Thanks
Feb 18, 2017 | AEG Washing Machines
How to fix a c2 error message on an aeg dishwasher?
C2 error may indicate a pump problem or too slow pump action this may be due to a blockage in the pump or a failed or failing pump capacitor this is not an expensive fix look for a replacement capacitor on Maplins of uk white goods web site you can get the size from the details on printed on the capacitor.
Apr 24, 2015 | AEG Dishwashers
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
AEG dishwasher C2 error
Dear Sir:
Please read the instruction manual for to fix this error.
If you do not have go for free download: www. fitness.manualsonline.com or www. retrevo.com
see the wiring diagram for help.
May 07, 2012 | Dishwashers
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Dec 29, 2010 | AEG Dishwashers
Aeg 60800 dishwasher showing c2 on panel,water still in bottom of dishwasher. will not start.
from other forum
Not pumping or pumping too slow. Check for blockages in pipework, filter and pump. If all clear, replace pump.
Curing the fault on these machines doesn't always get rid of the error code though. Some faults are locked in.
If you find this, post back and I'll try to help.
Mar 11, 2010 | AEG 24 in. Favorit 60800 Free-standing...
How to remove drain pump on AEG 88840 washer?
Hi
Not really a fix this but may get you going for a while.
We have a AEG 12710 update with what sounds like the same problem,If you remove the filter you can see the pump impellor and with the power off you can spin this a bit with a screwdriver etc and then box it back up and it should spring back to life for a few weeks.This is what we are having to do every few weeks until i get a new pump sorted.
Hope this helps
Apr 23, 2009 | AEG Lavamat 88840 Front Load Washer
My Aeg dishwasher keeps coming up witha C2 fault code
The pump out motor in line with the outlet pipe could be faulty. Remove the moto and connect it to the mains for a few seconds. The motor should spin and the impeler inside the motor should spin freely. If the motor is faulty it would not work and must be replaced
Mar 16, 2009 | AEG 24 in. Favorit 60820W Free-standing...
C2 error
aeg lavamar error c2
Dec 25, 2008 | Maytag NFW7200TW Front Load Washer
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Washing Machines Logo
129 people viewed this question
Top Washing Machines Experts
