Question about Epson Ex5210 Multimedia Projector
How to remove vertical lines from ex5210 projector
Vertical lines on screen
How do I make the picture smaller?
in front of the Projector there is a lens with a ring on it.. actually two of them, one is for size and the other one is for focus
tony
Feb 19, 2013 | Epson EX5210 Multimedia Projector
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
Ep716 has vertical line
IF THERE IS WHITE VERTICAL LINES IN YOUR PROJECTION THEN REMOVE THE MOTHER BOARD AND REFIT THE BOARD OR U CAN JUST PRESS IT FROM UPPERSIDE THE PROBLEM WILL SOLVE OUT
CHINTAN.A.SHAH
INDIA
Jul 23, 2008 | Optoma EP716 Multimedia Projector
White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
Vertical line
Hi there
The only way of fixing this is replacing or repairing the Mainboard.
This is a common Mainboard failure on Projectors
Nov 07, 2007 | Optoma H30 Multimedia Projector
Vertical Lines on the projector screen
When the vertical lines are displaying, open the projectors menu (by pushing the "menu" button). If the vertical lines affect the menu, it's a problem with the controller board and will need to be repaired. If the menu is NOT affected, it's probably a loose or damaged cable (Cable part# SP-DVI-A-R).
Oct 15, 2007 | InFocus LP70+ Multimedia Projector
Viewsonic Projector Blue Vertical Line
Hi guys
This is a common Mainboard problem on Projectors , unfortunately the Board will either need repairing or replacing.
No shortcutts on this one !
Aug 12, 2007 | ViewSonic PJ551 Multimedia Projector
Epson Ex5210 Multimedia Projector Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
