Question about Garden
Qualcast suffok punch 0.95 kw
Got no spark
2 Suggested Answers
  • 16 Answers
SOURCE: Please advise on where to puchase replacement
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Posted on Aug 31, 2009
Ihave just purchased a qualcast suffolk punch 30s the question l have, how do l check the engine oil level, l know were to fill the engine oil.Regards.Brian Bromley
Take the oil cap off with a flash light look in. take a stick or something small enough to put in the hole it shouldn't go all the way down. Where it stops that is where the oil level should be if you can't see any oil there thin add oil just to that mark. DO NOT OVER FILL .
Aug 02, 2016 | Garden
I got my qualcast 40 petrol chainsaw to start but the saw dies not turn. What's wrong?
Qualcast Product Support ' ManualsOnline.com
www.manualsonline.com/support/qualcast/
Manuals and free owners instruction pdf guides. Find the user manual and the help you need for the products you own at ManualsOnline.
Aug 08, 2015 | Garden
Where can I get a Manual for my Suffolk Punch Petrol Mower 17SK
Hi anon the easiest place would be QUALCAST direct.
Aug 11, 2014 | Garden
Why my 1996 golf from turn off while driving, it sparks but I won't start, need to wait 30 min and it will start with no problem but if it keep driving it it will do the same thing... please help me
which engine? see list , mind blowing, and what country>???
doing a 60k mile tuneup works, at least once a decade.
ever do the list of parts, spark and fuel , per operators guide?
that be first, 99% of bad running engines are that.
my guess , (weak based on only 1 fact) is has lost fueling
the ECU in the all cars 96 tries 10x to stop stalls.
the reasons are this: (top list)
1: lost 12vdc power ,see dash lamps or other lights go dead at stall>?
2: lost spark (tune up time?)
3: lost fueling, (try test fuel start now.
4: flooded, are the spark tips soaked in raw gasoline. (use wide open throttle cranking, does that work? this cuts fuel. (a secret mode)
5: ISC dead? (start car with 10% throttle) ok ISC is funky. clean it.
can you save the stall with fast right foot? (key fact here)
gen 3 engine list.
1.4 I4 40/44 kW (ABD/AEX/APQ)
1.6 I4 55 kW (ABU/AEA/AEE)
1.6 I4 74 kW (AEK/AFT/AKS)
1.8 I4 55 kW (AAM/ANN)
1.8 I4 66 kW (ABS/ADZ/ACC/ANP)
2.0 I4 85 kW (2E/ADY/AGG/AKR/ABA/AWG/AWF)
2.0 I4 16v 110 kW (ABF)
2.8 VR6 128 kW (AAA)
2.9 VR6 140 kW (ABV)
1.9 I4 D 47 kW (1Y)
1.9 I4 SDI 47 kW (AEY)
1.9 I4 TD 55 kW (AAZ)
1.9 I4 TDI 66 kW (1Z/ALE/AHU)
1.9 I4 TDI 81 kW (AFN/AVG)
Jul 10, 2014 | Cars & Trucks
Qualcast rm34 assembly
I'm not familiar with the Qualcast rm34 assembly, BUT... from the "smoke" from beneath, I suspect that something has jammed/locked the blades, or blade pulleys, and the resulting slippage of the belt is causing the smoke.
With engine off, AND the spark plug wire FAR REMOVED from the spark plug, CLEAN OUT ALL DEBRIS FROM beneath the deck, above deck, AND from all areas in contact with the belt!
May 04, 2014 | Garden
Replacing Tap on Qualcast petrol tank
It should just screw out, there is a thread on the plastic fuel tap, they can be pretty tight.
Jun 09, 2013 | Garden
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Aug 30, 2009 | Garden
My mower is not cutting level. I have a new base
If the baseplate meets the cutting cylinder across the entire cutting width, it's adjusted properly.
Check that the front roller is level - it usually IS as simple as that.
If the roller has ben replaced with wheels, check that they are the same height.
Aug 22, 2009 | Garden
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
