Question about Sony PlayStation 2 (PS2) Console
Shrek 3 the docks
Cant get past the level, have 3 mugs n cant find the rest.
  • Anonymous Apr 07, 2009
    cant lift up gold box& cant push open the gate
    Problem Solver:
  • 19 Answers
Check out game site not here
Posted on Aug 07, 2007
What does brewing time off mean
You can try the reset for the B60. I do bot understand your original What does brewing time off mean??...
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Jul 02, 2014 | Keurig B60 Coffee Maker
Why is my Kuerig B60 coffee maker not filling the correct amount of water. ie. a cup instead of a mug or 2 instead of 3rd level?
Your b60 may need to be descaled. There might be scale built up on the water level probes in you machine. I have listed the directions below:
Brewer De-Scaling Instructions
Brewer Model: Elite B40 ' Classic B44
Special Edition B60 ' Platinum B70
To begin, you will need the following:
• 48 ounces of undiluted white vinegar
• Large ceramic mug (do not use a paper cup)
• Access to an empty sink
PREPARE
Step 1:
Empty the water in the Water Reservoir.
Step 2:
Disable "Auto Off features."
FILL AND CLEAN
Step 1:
Pour approximately 48 ounces of the vinegar
into the Water Reservoir.
Step 2:
Place a large mug on the Drip Tray Plate and run a brew cycle.
DO NOT USE A K-CUP
, just press the BREW Button. Pour the contents of
the large mug into the sink.
Step 3:
Repeat the brew process without a K-Cup until"ADD WATER"
is indicated.
Step 4:
Now let the Brewer stand for at least 4 hours while still on.
Step 5:
Discard any residual vinegar and rinse the
Water Reservoir thoroughly.
RINSE
Step 1:
Ensure the Water Reservoir is filled with fresh water.
Step 2:
water brew cycle. Pour the contents of the
Step 3:
Repeat brew process until "ADD WATER is indicated.
Step 4:
You may need to perform additional water brew
cycles if you notice any residual taste.
NOTE:
If "DE-SCALE" is still displayed after
completing the procedure, repeat the
descaling procedure above.
Apr 14, 2013 | Coffee Makers & Espresso Machines
Dishwasher does not clean tea stains from teacups- we have tried a variety of soaps and have used sani-clean. Machine is only one month old- new fully integrated model.
Method #1
  • Wet a cloth then rub the inside of the mug with baking soda. If the stains are stubborn, soak overnight in hot water and baking soda.
Method #2
  • Soak the mug in bleach OR vinegar for several hours or overnight.
Method #3
  • Fill mug with boiling water, add two spoonfuls of dishwasher detergent then soak overnight.
Method #4
  • Try a paste of corn starch and vinegar, apply and let sit for a few minutes then scrub away.
Method #5
  • Drop two denture tablets in the mug, pour hot water over top then soak overnight.
After soaking mugs and removing the stains, rinse and wash very well before using-especially when using the bleach method.
May 06, 2011 | Samsung Dishwashers
I have the B60 model. It has been wonderful from day one and then...today...I made 2 cups this morning, went back about 2:00 to make another and it was off. Hummm...so I tried to turn it on and it will...
Try the following steps to reset the processor:
1. Simultaneously press and release ?small mug? and ?medium mug?. Immediately afterward press ?menu? 3 times. You should see a time 6:09 (or similar) on your screen.
2. Press ?menu? once. Your LCD screen should say Brew 0:00.
3. Press and hold ?medium mug?. While holding ?medium mug? press and release ?menu?. Immediately after releasing ?menu? (while still holding ?medium mug?) press ?small mug?. Release ?small mug? and ?medium mug? at the same time. This entire thing needs to be done very quickly.
4. Unplug the machine (do not turn it off). Wait for 3 minutes or so. Plug it back in, turn it on and follow the instructions for priming.
Jan 05, 2011 | Keurig B60 Coffee Maker
I need directions to shrek 3 game for ds
if you mean instructions, Left or Right on D-pad move the characters, L initiates magic mode and you use the stylus for everything else.
Apr 15, 2009 | Shrek The Third for DS
Shrek 2 Activity Centree will not run on Windows XP SP3
I had this problem and I went to the Program Compatibility wizard in XP.
Start
Accessories
Program Compatibility Wizard
Choose from list
Select Shrek 2 click next,
Follow all of the suggestions that they give. They will walk you through each step to try.
I followed each one and found that Compatibility mode for Windows 98/Me with 640x480 screen resolution worked after I did the display adjustments listed below.
I went to Display Properties, Advanced, Troubleshoot, slid the Hardware acceleration all the way to the left and unchecked the enable write combining box. I had to restart the computer after I did this, but now the game loads.
Mar 08, 2009 | Shrek 2 Activity Center
Cant get through level 6 on shrek the third
shure you can you only have to throw stuff on the monster
Feb 25, 2009 | Activision Shrek The Third for PlayStation...
I cant get the door open in shrek
i still need help on solving this shrek ps2 door to open
Feb 03, 2009 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
41 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
