Question about Air Tools & Compressors
Mastercraft compressor Need a new regulator valve for a 5 gallon-2HP air compressor #58-8097-6
SOURCE: Tool side has no pressure
if there is sufficient air in the tank the regulator valve is either set to low or is stuck. if its stuck ur better off to buy a new one and replace the one u have.
Posted on Dec 11, 2008
gaeb7
  • 25 Answers
SOURCE: 25 gallon air compressor wont shut off,changed air regulator
You have a valve plate problem . It could be a slipped "o" ring to a bad reed valve. There are rebuild kits for that purpose. The kits include a valve plate assembly. It covers all the bases. When you look at this area pay attention to the partitions of the head gasket/"o"ring. You may avoid the cost of the kit.
Posted on Feb 25, 2009
  • 22 Answers
SOURCE: when my cratsman 2hp 4 gallon air compressor gets
If there are no major leaks and the pressure gauge shows no significant pressure loss yet the compressor cycles on and off every few seconds, then the air pressure switch is not set correctly. Go to http://www.generalairproducts.com/fireprotection/images/stories/Pressure-Switch-Adjustment-042705.pdf It shows how to set various pressure switches.
Posted on Mar 24, 2009
miket756
  • 2702 Answers
SOURCE: How are the valve plates seated on an 8 gallon
the velves are called "reed velves" look from under the head at the velve block as if you were the piston, as the piston gos down it pulls (open)the inlet velve (but the out let velve is held closed by spring presher) and on the way up it (pushes closed on the inlet velve) and pushes the out let velve open so air can be pushed into the air tank,,,has this helped you? they are held in place by light spring presher and maybe fasend by a bolt?
Posted on Oct 25, 2009
SOURCE: How much oil for 2hp 8 gallon central pneumatic air #95386
i'm not sure of the solution but what type of oil did you use?
Posted on May 29, 2011
I have a mastercraft compressor with LCD display its 11 gallon,it runs up to about 70 psi and will not go higher but keeps running, any ideas.
You either have an air leak somewhere or you have a damaged valve in the valve body. You can check for leaks using a spray bottle with a dishwashing detergent/water mix. Spray the mixture on connectors and look for bubbles. Don't forget to check the tubing coming from the compressor head and the regulator. If you find no leaks (you need to check carefully), you might need to remove the compressor head and check to see if the valves in the valve body are damaged. My Campbell-Hausfeld compressor did the same thing and I had to replace the valve body.
Mar 08, 2017 | Psi Air Tools & Compressors
What's wrong with my oiless air compressor
Sounds like the reed valve or valves in the head failed. When you unbolt the head you will see a thin piece of metal that is the valve assembly. If it is not all one piece it is broken and needs to be replaced.
Apr 25, 2014 | Garden
Mastercraft 5 gallon compressor
you can try replacing the seals first but i would recommend rebuilding the valve
Jan 23, 2014 | Garden
Compressor runs, builds up pressure, but wont come out of hose/???
When the pressure regulator fails, no pressure will be available at hose. Replace the regulator with generic available at Lowes or bypass. To bypass the regulator (this method will give you full tank pressure to hose) remove the safety valve (or gauge if it threads directly into tank) and install a tee fitting. On one side of tee fitting reinstall the safety and the other port is for quick connector. You can also install a regulator here if you would like to save time and the old regulator is difficult to remove. Good luck
Feb 12, 2011 | Clarke Power Products Inc AC2001 2HP 4...
Where can I purchase a new pressure regulator for a Clarke ac2001a pancake air compressor?
Harbor Freight should have this or be able to order it for you and usually take them bout three days to get items in.
Oct 28, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Don't know how to adjust differential pressure on air compresor
Most of the cheaper compressors use a switch that is not adjustable.
May 12, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Dec 04, 2008 | Campbell Hausfeld 28 - Gallon Air...
Air Tools & Compressors Logo
360 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
