Question about HP P2055DN LaserJet Monochrome Printer
49er 3D90A47 - HP P2055DN LaserJet Monochrome Printer
Who made my 20inch 49er bike serial nu mber dm051030961
There is no universal serial number database for bikes (or for pretty much any other product other than cars for that matter). Why do you need the info?
Mar 06, 2016 | Cycling
Is there a diagram of how to run the belt on the tensioner, have new belt around drum already. Don't know what it is suppose to look like. Thanks Dave Ball at (the.49er.miner@gmail.com)
Man Im not sure if this info will help you but. On my dryer which is pretty much the old style, standard type dryer and I had to replace the belt and had a little trouble putting it on the tensioner, finally figured it out.. If you take the belt and pinch it together and pull under the belt tensioner and then around the moter shaft that's what you do for the dryer style I have.. HOPE this may HELP!!
Jun 20, 2011 | Samsung DV218AEW Electric Dryer
I have a sachs 49er 07 plate Does anyone know what Tire pressures are meant to be????????
Look at the sidewall of both tires. There will be a 'MAX PSI' embossed on the tire. It will probably say Max 45 PSI. At 45psi the bike will ride like a rock. At 15psi it will ride really squirrely. Find a psi at which you feel the bike handles well and rides well. One rider may weigh 125 pounds and the next rider may weigh 300 pounds. The best psi for each rider will be different due to weight. Chances are that 30 to 35 psi will do the trick.
Sep 13, 2010 | Sachs XTC-N Motorcycles
Wiring on a scooter
try sachsinfo.wiring i did it for my honda
Jan 26, 2009 | 2000 Sachs Roadster V1.6
The igniters wont light the burners
49er, if none of the igniter switches work you're on the right track. Follow those wires and you'll come to a "spark module". This will need to be replaced. Part number 74008821... lists at about $21.00. Good luck and let us know how it turns out.
Sep 26, 2007 | Maytag MGR5751AD Gas Kitchen Range
HP P2055DN LaserJet Monochrome Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
