Question about Dishwashers
Ecolab es2000 dishwasher
How to delime.
2 Suggested Answers
bigg t
  • 640 Answers
SOURCE: dishwasher says delime on screen, how do i do this?.
Hold the delime button in and hit the on button for 5 seconds.It will then do a partial fill then it will say add delime,add delime shut the door and press the wash button.Let the machine do the rest it will turn itself off when finished.
Posted on Feb 14, 2009
Instruction Manual for Ecolab EC-66 dishmachine
Try Googling (Ecolab)(EC-66)(manual) without parens.
Apr 13, 2018 | Dishwashers
What brand of deliming agent should be used when deliming this unit?
The chemicals used for this unit are not brand specific. As long as you are using a commercial-grade delimer, you will be fine. Do not pick up a delimer from your local supermarket. Those are not designed for commercial warewashers and can cause further problems. Ecolab is a common brand used . The have a delimer called Lime Away that is very widely used. Also, please remember to drain the water out of your dishwasher and disable your detergent and rinse aide before filling it back up. Then add your delimer and run the unit in manual mode for as long as necessary. Then, drain the unit again, rinse out the wash tank area, enable your detergent and rinse aide, and fill the unit back up. You should be ready to run now.
Jun 17, 2015 | Meiko K44E Dishwasher
Is there any place to get parts for a ecolab dish washer ? I need two valves for it, can i get a parts list for it or an exploded view of it ?
you could contact ecolab and get parts
1-800-352-5326
what kind of machine?
Es2000 or Es 4000etc.
They are jackson machines
Jan 05, 2011 | Dishwashers
How much delime agent should I use to clean the system in a Hobart LXI-H?
Depending on how often you delime the dishwasher use 2 cups.The delime light will come on after 1000 cycles set from factory default.If the delime icon is lit and beeps,turn the unit off.
Push and hold the delime/wash button and on button for 5 seconds and youll be in delime mode.
The unit will fill and heat up and display "add delime".Open the door add the delime and press the wash button.The dishwasher will run for 5 minutes then rinse and drain twice then shut off.When you turn it back on the delime icon will be gone.I'm a hobart tech and repair these dishwasher often,any questions let me know and please rate me,Thanks.
Nov 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
How do you delime the hobart LXi. Where can I find the manual online?
With the unit off----hold the wash/delime button in and hold the on button in for 5 seconds.the dishwasher will fill and the delime icon will be on,then it will prompt you to add delime,add the delime and hit the wash button.It will run for 5 minutes,fill up twice and drain twice then turns off.
Feb 26, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher says delime on screen, how do i do this?.
Jan 29, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart Dishwasher
You will need a delimer. This is typically a liquid chemical purchased from your chemical supplier. Personally, I like Lime-Away from Ecolab
Aug 19, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
D-lime
they make a deliming solid and a liquid (liquid Chisel) and the solid one is in a little plastic tub you place it on a rack and it disolves inside the machine I belive you can buy them from ECOLAB hope this helps
PS: if using the liquid wear gloves and goggles it is caustic
May 09, 2008 | Hobart AM14-253 Free-standing Dishwasher
Dishwashers Logo
348 people viewed this question
Top Dishwashers Experts
