Ruud uhka-hm3617ja - Heating & Cooling
I need a Ruud 80 plus gas furnace manual
Request the manual directly from Ruud.
Mar 25, 2017 | Ruud Heating & Cooling
Rheem air conditioner RHSL-HM3617JA how do I change the air filter
Air filter tray is integrated into the unit.
There is a door on the face at the bottom.
The door pops open and the filter slides out from the side.
The filter is MERV 8-13 depending, size 17.5x21x5 (17.25x20.75x4.38) It costs 30-70 dollars, but changing is very easy.
May 13, 2011 | Water Heaters
I have a Rheem Model RHSA-HM3617JA and need a wiring schematic so I can wire in the thermostat
We can get you the wiring diagrams for your Rheem model. Not sure how to attach a PDF to this area, but if you contacted us either by phone or e-mail, we can send it to you via e-mail. You can contact ComfortGurus.com at 866-519-2461 or visit our site and use the "contact us" page to send us an e-mail. We are a full-line Rheem distributor for parts and accessories if you need any parts in the future too. Let us know if we can help.
Oct 18, 2010 | Heating & Cooling
The Ruud breaker (60amp) with a integrated pigtail is not delivering the correct voltage to the lower part of the handler. This breaker is part of the heater insert inside a UHSA-HM3617JA I want to get...
The breaker in the unit is for the heat strip.Are you trying to heat?If so It should give you 240v from it.I know those breakers are pretty cheap and home depot,and usually cheaper than calling a a/c tech.Good luck
Aug 06, 2009 | Heating & Cooling
We have a fairlynew 5 ton Central Ruud or Rudd unit that it is so noisy in the yard that we can not stay out there. We thinkit is the compressor. Help
I have a new 13 seer rheem or ruud same thing. I can not here it run. Uou must have a bad compressor. Ruud put schroll compressor in and when they start to go out they will drive you nuts they are so loud. Get it changed before your warranty runs out. Ruud will change your compressor if it to noisy. No problem. Russ
Jul 20, 2009 | Ruud Central System Air Conditioner
Rheem Air Handler will not run. This is a 2006 Rheem model RHLA-HM3617JA Air Handler. I replaced both the condenser and air handler circuit boards. I replaced the motor in the air handler.. The condenser...
Have you hard wired your fan motor to verify that the motor and or the capacitor are good? If you do a continuity test of the motor leads(with electricity off of course) you can see if the motor has open or grounded windings.
Apr 11, 2009 | Ruud Handler Air Conditioner
Electrical Schematic for Ruud URGG-10E37JKR
just a maybe , write to RUUD AT P.O. BOX 17010 , 5600 OLD GREENWOOD ROAD ,FORT SMITH ARKANSAS, 72917-7010, OR CALL 479-646-4311 AND SEE IF THEY CAN TELL YOU WHERE TO CALL FOR SAM.
Sep 20, 2008 | Ruud UAMB Air Conditioner
Could you diffrentiate LG and RUUDE make for me
I have seen much more Ruude products out there. LG must be a lower end brand. Lg also makes smaller air conditioners
Jan 29, 2008 | Ruud Central System Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
