Question about Sharp Office Equipment & Supplies
Sharp el 11979p display light dim
Display light dim
  • 359 Answers
SOURCE: Sharp EL-2630GII Error on display
Unable to locate a manual for this specific model, but if you go to http://www.sharp.ca/manuals/, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 08, 2008
SOURCE: how do i display exponents besides 2, or 3 on the
EL-531W SHARP:
If you want to find 5 to the power of 6 (5^6)
you hit the 5 button, then the button that says yx ( the x is in the exponent spot) then the 6 so it will looks like this 5^6 then press enter to get the answer...hope that helps!
Posted on Sep 10, 2009
SOURCE: display problem
Hi, I had a similar problem and fixed it. Open the calculator and you will see that the ribbon connecting the LCD to the PCB has white and black stripes. The black stripes are the actual conductors. The white pieces are isolation between the conductors and serve the purpose of glueing the ribbon to the PCB.
Take a small flate screwdriver, its thickness has to be that of the white stripes. Heat up the end of the screwdriver with a hot air gun/lighter/hair blowdryer or whatever. Dont make it too hot. It should only be hot enough to melt the glue holding the ribbon to the PCB. Press the screwdriver on a white stripe and move the screwdriver up and down the white line which is on the PCB. Do this for each white stripe individually. Reheat the screwdirver if necessary, since there are a lot of tracks/stripes to cover.
It may be useful to use two screwdrivers: one to heat the glue of a white section and a second to cool/set the glue so that the ribbon is held in place, instead of coming loose because the glue is too hot. I did it only with one mildly hot screwdriver. It shouldn't be so hot that it actually burns you. You can test the temperature by pressing it against a hot melt glue stick (those used in a glue gun), if it melts the glue (but not too quick) it is hot enough.
It is unlikely that the ribbon came loose from the LCD, but if the previous didn't work you can try doing it on the LCD aswell.
Posted on Oct 26, 2010
reyjoshua07
  • 1157 Answers
SOURCE: My Sharp 2 color EL
Hi eegil2,
Have you tried resetting it? If not please follow the steps below.
1. First press the reset button.
2. When the display says "RESET OK ?"
3. press the CAPS button then the button marked "2nd" (bottom left hand corner) then press Enter.
4. Display will then say "BUSY". Reset is then complete.
Hope it helps.
Thank you for using FixYa.
Posted on Aug 17, 2011
  • 102366 Answers
SOURCE: How do I get my SHARP EL-520W ADVANCED D.A.L. to
Unfortunately, you don't. The EL-520W can show fractions, but not radicals.
Posted on Apr 06, 2012
SHARP ALARM CLOCK HAS DIM DISPLAY
Some clocks have a display brightness adjustment.
Jun 25, 2017 | Home
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
EL 531X Sharp - Help with calculations
You need a SHARP with Write-View display capabilities. The EL-531X is unable to show that. The Write-View calculators from Shard have a W, example EL-W516 followed by Write-View. Not to be confused with the W in EL-520W
Feb 21, 2013 | Sharp el-531x scientific calculator
The display on my Sharp Grill 2 Convection Model R 82ojs-f is too dim to read.
either the display is bad or the unit may have a setting in the menu for adjusting the brightness level
Dec 04, 2012 | Microwave Ovens
My calculator will show fractions instead of decimals when doing division. How do I change that? There is a N1 displayed in the lower left corner also...I think that may be the problem
Getting Decimal Answers by Disabling WriteViewelw516.gif on the Sharp EL-W516 Calculator
If you prefer to always get decimal results you need to disable the WriteView display mode. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.
Disabling WriteView
NOTE: It is not possible to have decimals as the default answer form when in WriteView mode.
Feb 07, 2011 | Sharp ELW516 Scientific Calculator
The calculator is intermittent: Most of the time
Not knowing what to do, I tried anything that could possibly help:
I installed fresh batteries and I pushed the reset button on the back of the calculator (Sharp EL-546L) and finally, it work all right after more than 5 years I own the calculator and where it did work correctly for 5 minutes. I tried the reset button in the past (long time ago) and it didn't work. This time it worked because, maybe, I've used fresh batteries.
Marcello
Jun 03, 2009 | Sharp EL-738 Scientific Calculator
Need Sharp EL 5102 Financial Calcualtor User Manual
I have a manual. Are you still looking?
Have the calculator too... but the display doesn't seem to work.
I loved that calculator - wish I had another.
Roger
1withall@live.ca
Nov 16, 2008 | Sharp EL-1801P Calculator
Mar 26, 2008 | Sharp EL-2630P Calculator
Display not showing correctly
Did this machine get wet? Or was it dropped? It sounds like the lcd display is either damaged or defective! John
Jun 12, 2007 | Sharp EL-334AB Calculator
52 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
