AW24PKBCXAX My a/c doesn't cool enough. The air tempature coming out is about 40 degrees. Three lines on the side keepfreezing up.
txkjun
  • 409 Answers
SOURCE: Air Conditioner for Benz 1998 E320
Check system for codes;
Displaying & Reading Trouble Codes (DTC Memory)
Air Conditioning (A/C)
Models 208 as of MY 1998
Diagnostic trouble Code Memory [15]
Note:
  • The A/C pushbutton control module (N22) has DTC memory and data output. The diagnostic trouble codes and data are displayed via the temperature display window. The stored DTC's will remain in memory even with the vehicle battery disconnected.
  • The DTC memory differentiates between current and intermittent faults.
  • Numerous DTC's can also be read with the Hand-Held Tester (HHT).
Preparations for DTC Readout
  1. Review 11, 12, 13, 14, 15, 21, 22, 31, 31, 41
  2. Ignition: ON
  3. Temperature selector: left: "HI"; right: "LO"
  4. Ignition: OFF
  5. Ignition: ON
  6. Within 20 seconds press REST and EC simultaneously for more than 5 seconds.
  7. The LED in Recirculated Air flashes and the display shows "d1A".
  8. Press AUTO repeatedly until all DTC's are displayed. Record each DTC as it is displayed.
  9. Each fault (short circuit, open circuit) is assigned a DTC. Thus in the left display: "E1" appears, and the right display indicates the DTC. The current faults (refer to table) are displayed first, next, the intermittant failures (e.g. 45 °5) are displayed in the display window next to the FAN symbol. By pressing the right AUTO the next DTC is displayed.
  10. To erase: Can only be performed after all faults have been readout. Press left AUTO and right AUTO buttons simultaneously for more than 2 seconds and the display shows: left: "d" and right: "FF". To cancel erase: By pressing the left AUTO button, the current faults will appear again.
  11. Select a base temperature setting.
  12. Turn ignition OFF, to end test.
Note: Due to instrument cluster (IC) series interface, DTC's may be stored in IC memory, therefore readout and erase DTC's from IC memory.
133090425133090426
Posted on Dec 30, 2008
  • 20 Answers
SOURCE: heater blows cold air when it is 30 degrees out side
heat pumps don't work as effient at that temp thats why they have 2nd stage supplemtial heat
Posted on Jan 09, 2009
  • 531 Answers
SOURCE: GE side by side fridge not cooling enough Freezer side was still
check see if you have frost build up in the freezer back wall you may have defrost problem
Posted on Apr 06, 2009
SOURCE: GE GSS22 refrig wont get cold, freezer does.
Hi, it's possible you have a defrost problem, to know if you have a defrost problem, you should unplug/disconnect refrigerator, remove your produce, leave doors open, for faster defrost, clean and leave unplug/disconnected for about hour, be cautious you will get excessive water from defrosting. let freezer defrost completely, then plug/connect refrigerator, let it work/run for an hour, if it's o/k, put back your produce, if it work good/ o/k for 3 to 4 days and start doing the same thing, you got a defrost problem, defrost problems are caused when excessive ice build up on your evaporator, two things could cause a defrost problem. (1) excessive moisture/ hot air entering refrigerator, hot days,hot foods, regular opening, to close heat source, range/ oven. in cases like that, cleaning of refrigerator will normally solve that problem. (2) faulty defrost heaters, defrost thermostat , located in back of freezer side, you will have to remove shelves and back panel, to get access to it,also check your defrost timer and speed of fan, but first disconnect refrigerator, clean and try , before changing any parts. it could just be excessive moisture. always remember to disconnect your refrigerator before attempting any repairs, let me know what happened, then i could tell you exactly what's problem. good luck
Posted on Aug 19, 2009
Sea Breeze
  • 4654 Answers
SOURCE: my frig is running but not cooling - frig is 50
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Posted on Jan 23, 2010
Testimonial: "Thanks for the quick help - yes frost on back wall. Once I unload and defrost should I then take out defrost thermostat? "
I have a 2005 dodge durango that's over heating.
The basic answer is not enough coolant flow or not enough air flow thru the radiator. You'll have to find out if the coolant is flowing when the thermostat is open, is the system full of fluid, and is there enough air flow thru the radiator.
Does it get over 220 degrees if you are moving and at idle too ?
Jun 17, 2013 | Cars & Trucks
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I have a 2006 chevrolet impala ac not cooling been charged and vacumed
To answer your other question, the only filter in the system is the accumulator which is the large can near the firewall.
The orifice tube could be stopped up but the ac is a closed system, so if there is something clogging the line it had to come from the compressor or other component.
Do you know for sure the system is full, and if so what are the low and high gauge readings at idle ?
Jul 21, 2012 | 2006 Chevrolet Impala
Ive owned the 10x6c for 2 years never used it because of my wiring doesn't have a ground,,let my neighbor borrow it and it doesn't blow cool air I hear the compressor turn on but no cool air?
If the compressor is coming on and the air is not cold, it could be that the freon has leaked out. Easiest way to check for no freon is to take the cover off the unit and run it in cool. The high side which is the smaller line coming into the top of the compressor should be hot, and the low side which is the large line coming off the side of the compressor should be cold when the compressor is running. If there is no temperature difference between the high side and low side tubing, you have no freon. Also check for oil residue once you have the cover off. If you spot oil, you had a leak and have no freon.
Aug 14, 2011 | Haier hwr10xc6 Air Conditioner
I just purchased a kenwood a/c a couple of weeks ago it's a G130EK, 13,000 btu and it doesn't cool anything not even a 12 x 12 room. There is an opening that leads to a bigger room , but the...
Air conditioners generally cool the air 15 to 20 degrees. 80 degrees in return should be 65 in supply. 70 degrees in return should be 55 in supply. If the a.c. is in that range it is working fine and doing all it is going to do.
Jul 02, 2017 | Kenwood Heating & Cooling
My air conditioner dwc 084 rl model does not work well, can not maintain a temperature below 70
The air is cool but doesn't seem cold enough If the air doesn't seem cool enough it is necessary to use a thermometer to check the difference in temperature between the air going into the unit and the air being blown into the room. Ideally, the temperature difference should be more than 15 degrees. For example, if the temperature going into the air conditioner is 80 degrees, the temperature coming out of the unit should be at least 65 degrees or less. If the difference is 15 degrees or more there is probably no cause for concern. If the temperature difference is less than 15 degrees you should check the following:
  • Air damper
Check to make sure the air damper is closed. If it's open, it will bring in outside air and reduce the efficiency of the unit.
  • Back cover
During the winter season many people cover their air conditioners to protect the unit from the weather. In the spring or summer they will sometimes forget to remove the cover. If your unit has a cover on the outside portion of the air conditioner remove the cover first.
  • Condensing coils
The condensing coils will always be on the "warm" side of the air conditioner. That is, on the side that faces outside of the room to be cooled. Air is drawn into the back of the air conditioner on the sides through vent slots and is blown directly out through the condenser coils. If the coils get clogged with lint, dust and dirt the cooling system cannot provide the cooling necessary. To clean the coils it will be necessary to remove the entire cover of the air conditioner or pull it out of the wall to gain access to the coils. They can be cleaned by blowing compressed air at them or by using a soft bristle brush to wipe the dirt off. It is important to also clean any dirt or lint build-up in the bottom of the air conditioner so the condense water will be picked up by the condensing fan slinger properly.
It could also mean that you are trying to cool too big an area for the size of the unit.
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
Jul 22, 2011 | Daewoo Heating & Cooling
I have Model: DM30A which constantly freezes up even though it is on a three foot high table and the temperature never goes below 60 degrees
The unit freezing up doesn't surprise me at all. If the temp in your room is 60 degrees then the temperature of the air will be around 40 degrees and the coil is about 20 degrees. Your expecting to much, the tempature is to cold to work properly.
Jul 08, 2011 | Haier Dehumidifiers
Model RT14HDXGW02 Refrigerator compartment wasn't
Yes its possible that the defrost water instead of going down the drain properly, its clogging the airways. pull the covers off and see if the defrost drain is plugged or frozen. clear it if its plugged and make sure panels and gaskets go back on properly
Jun 24, 2011 | Roper RT14DKX Top Freezer Refrigerator
Moisture/water buildup
It sounds like your T-49 is not maintaining a low enough temperature. I would put a mercury filled thermometer inside and monitor the temperature. Your unit should maintain a temperature lower then 40 degrees Fahrenheit. I usually set the units I work on to come on at 39 degrees and turn off at 33. The moisture should condense on the coils.
Jan 24, 2009 | True T-49 Side by Side Refrigerator...
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
