Question about Holmes Products HASF1710-UC Stand (Pedestal) Fan
How do replace the fuse in the fan cuz it stopped working
MY PROBLEM IN MY MIT LANCER 2010 IS, WHEN I STARTED THE ENGINE FOR THE FIRST TIME, LET SAY IN THE MORNING, BOTH FANS WILL WORK BUT AFTER SOMETIME, AC FAN/BLOWER WOULD STOP AND NEVER WORK AGAIN
i read that ur problem is with a Mitsubishi lancer, and not an f-150. or u r question reflects sumthing else. nun the less :mit lancer ac fan is governed by a thermal shut off. if u use it it will run, if not it will shutoff. NOW: f150?? relays r in the box under the dashboard driver side. chk fuses first,cuz relays r tough to git at.lol!
Apr 06, 2014 | 2004 Ford F150
Fan wont always come on when a/c is turned on. If it were fuse, would it never work? Works randomly. A/C is working cuz I can hear it come on every time. Is there a relay switch for fan? If so wher
typically the fan will only come on if the high side a/c pressure reaches a certain pressure. Are you sure the system has a full charge?
You are correct that the fan would not work if the fuse was blown. It may intermittently work if the fan motor was going bad or there was a bad relay, or if a sensor was flaking out, or if there was a problem with the wiring.
I would start with making sure the system is fully charged or at least hooking up a set of gauges to the a/c and seeing what the pressures are at.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Aug 13, 2012 | 2005 Buick LaCrosse
1993 mazda mx6 wipers delay stop working other speed work stop where ever shut off
Weres the fuse for the wipers I bought the car and the guy said he took out the fuse cuz they won't shut off
Jan 13, 2012 | Mazda MX-6 Cars & Trucks
My1994 cadillac seville fuses are missing so my odometer n the heater n the ac are not working but i have an extra fuse in the car cuz they gave it to me for free.. but how im gonna change or put them in...
Issue with Main Fuse Panel Box....Please refer to Manual for correct Fuse Amps... On the Back of your Cover you will see a diagram color code Check and Re-place the fuse The most comon Fuse are (Blue 5amps) (Green 10amps) (Red 20 amps) AC are differente section... Replace with Red 20amps Use Fuse only dont jump them You may have a issue with the fan motor.. look under the hood passager side... easy to change ....S20 dollard on junck yard.... good luck
Sep 28, 2010 | Heating & Cooling
Coolant light is on replaced thermostat, fan not working. i have a 1999 chevy caviler what should i do
REplace the temp sensor then top off the coolant to avoid overheating. Fan will not work cuz sensor doesn't send signal that the coolant is hot enough to warrant a cooling from fan.
Aug 11, 2010 | Chevrolet Cavalier Cars & Trucks
Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
I just changed the radiator of my 2001 Maxima and the fan stopped working. It was working fine before I changed it. We checked the fuse, thermostat, wires and they all good. the mechanic told me that the...
The ECU drives a relay which in turn drives the fan. Trace the fan wiring back to the relay and check the plug connection. Does the fan turn freely by hand? If not, replace it. The fan needs a solid ground connection as well as power from the relay.
Aug 04, 2009 | 1988 Nissan Maxima
Dont want that cold cuz iam already ther
The heater element sensor are open or fuse/ motor ok /flow of air ok heater is the problem.replace fuse or heat sensor if open.
Jan 08, 2008 | Heating & Cooling
Holmes Products HASF1710-UC Stand (Pedestal) Fan Logo
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
ray gallant
xkikbxr
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
