Question about Panasonic Linear ES 8068 N
Panasonic ES 8068
My blades and foil needed replacement so I replaced them (with correct parts). Over about a week, the charge went down to zero on my shaver (someone had unplugged the cradler/recharging station and I didn't realize it). I recharged it just fine, but now the shaver won't turn on. The unit shows 100% charge, but nothing happens when you turn it on. Any ideas?
SOURCE:
  • 42 Answers
SOURCE: My shaver doesn't stay charged very long
The motor is fine, what happens is that the internal battery loses the ability to fully charge and run the motor for a long period of time. While you "could" change the battery out with a newer one using solder, it's unlikely that it would cost less than buying a newer model at the store or from ebay. The average life of good shavers made a few years ago was about 3-5 years due to the type of batteries in it. I used mine with a charging cord for a while but that became an issue once while traveling. I bought a new one.
Posted on Nov 09, 2007
  • 3422 Answers
SOURCE: Foil for my electric shaver?
HI,
You can get the parts from HERE
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 05, 2008
I need to change my Hitachi Phase 4 shaver foil of RM-8670B urgently please. Where can I buy it?
Posted on Oct 22, 2008
  • 14 Answers
SOURCE: wet/dry Panasonic shaver stopped
My model is almost the same as your model ...
Problem: Model ES7037CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg 12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
Posted on Dec 27, 2008
VtToolMan
  • 704 Answers
SOURCE: Braun 5614 rechargeable cordless shaver light flickers
Your batteries are starting to degrade, but the good news is they're still holding a charge for a week, so you really don't need to rush to replace them at this point.
The flickering of the charged indicator is normal, as the shaver is still plugged in and the batteries are fully charged. The flickering is due to the batteries chemicals breaking down, and as such, the charge cycle keeps "topping" them off while it's still plugged in.
When you finally aren't able to get a decent amount of cordless operation and run times from your shaver, then you'll want to get them replaced, whether you decide to do that yourself or have it done by a professional service center, is up to you.
Here's a reference for your future use. www.electricshaver.com carries replacement (factory OEM) batteries for most brands of shavers and they also will provide the repair/replacement service for you, should you decide you don't want to do it yourself. You can also give them a call at 1-888-476-1785 and request a price quote, etc.
Anyway, your shaver is working fine and all you need to do is make sure you're not letting the shaver stay plugged in and charging constantly for more than a day, since any "extra" chargind isn't doing anything except keeping the batteries at a constant state of charge. Heat is a byproduct of charging and discharging any battery and as such, you want to allow for a cool down period before recharging them.
I tend to use my shaver until it is almost completely discharged before recharging it. By doing this, you can get the longest working life out of your batteries before you'll have to replace them.
Hope you find this Very Helpful and best regards!
Posted on Oct 23, 2009
Testimonial: "very helpful"
Need a trimmer replacement
panasonic WES9025PC replacement outer foil and inner blades set for electric shaver panasonic es la63 replacement parts.
And panasonic es la63 parts is also separated foil and blades, then panasonic es la63 replacement foil is WES9165PC and panasonic es la63 replacement blades is WES9068PC.
Feb 06, 2013 | Panasonic ES-LA93 Shaver Electric Shaver
Hello.I can not find a part of the shaver panasonic es8043, and even don `t know how it is called correctly. to form a fragile plastic part that transmits vibrations to the blade. and on which the blade is...
panasonic WES9085PC replacement outer foil for electric shaver panasonic es8043 screen foil replacement parts.
panasonic WES9064P replacement inner blades for electric shaver panasonic es8043 cutter heads replacement parts.
Mar 10, 2011 | Panasonic Health & Beauty
Panasonic shaver Model ES8068 Linear pulls facial hair rather than cut
panasonic es8068 replacement foil and blades is panasonic WES9079P replacement outer foil and inner blades.
panasonic es8068 replacement blades is panasonic WES9070P inner blades.
Sep 02, 2010 | Panasonic Linear ES 8068 N
ES 8003 needs new battery, new blades ?
You will find foils and cutters for this model at shaveroutlet.com. See links below
http://shaveroutlet.com/panasonic-wes9080p-cutter-blades-p-85.html
http://shaveroutlet.com/panasonic-wes9081p-shaver-foil-p-86.html
Original Panasonic batteries are not available in the market, however, there is a suitable replacement. You will also find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
Apr 03, 2010 | Panasonic Linear ES 8003 W Electric Shaver
Panasonic Linear ES 8068 N Logo
313 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Rick Goldsmith
Rick Goldsmith
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
