Question about Sony Handycam CCD-TRV68 Camcorder
GG/ BOY I DON'T KNOW WHAR ROCK YOU HAVE BEEN UNDER, BUT THAT IS NOT A TRUE STATEMENT ABOUT ANLOG NOT PUTTING DATE AND TIME ON MOVIES. IHAVE THE SONYCCD-TRV68 AND I HAVE 126 MOVIES MADE WITH IT AND THEY ALL HAVE THE DATE AND TIME STAMPED ON THEM
I have tojumpstart then dash comes on/ihave a burnt wire or switch,don,t know where to look
i think you burn out fuse to starter and dash
remove side cover on kickstand side
check fuse. it looks like a thin metal strip under two screws and has a cover plate.
if burnt
should have a replacement one right there.
check all fuses
Sep 12, 2014 | 1984 Honda GL 1200 Aspencade Gold Wing
Tip
Truly/Accuread DB61M Blood Pressure Monitor - how to set date and time
I found how to set the date and time on my Truly DB61M blood pressure monitor by trial and error. I suspect other Truly BP monitors do it a similar way. These monitors also seem to go under the name Accuread. It's a pity they don't make manuals readily available online.
Here's how you do it:
1. Put the monitor into the date/time setting mode by holding down the MEMO and AVG buttons together for several seconds, then release.
2. The YEAR will be displayed flashing at the top right of the display. Press the PAGE button to move through the years to the one you want.
3. Press the AVG key to move to the next field, which is the month, flashing on the left. As with the year, used the PAGE button to move through the months to the one you want.
4. Following the same procedure, set the day of the month, the hours and minutes. The monitor knows how many days are in each month, so you can't set eg 31 February.
5. To finish, press the START button (the one on the right with the red marking).
There seem to be some other settings as well as the date/time that come up if you keep pressing the AVG button, but I don't know what they are.
on Feb 13, 2014 | Truly Health & Beauty
Password on Bios of sony vaio VPCEB46FG
You don't need to put a bios password on it.
If the bios already has a password on it then it will not let you boot the computer without you putting it in. It sounds like you are already booted up and into the bios, if that is true don't set a bios password.
May 13, 2012 | Computers & Internet
Trying to save a few bucks. bought rear tire for 2000 FLSTF and going to swap it out myself but don't have the owners manual. Are there any tips and tricks you can advise me on? I am very mechanical,...
Yes, that is true on most bikes but I don't know if you're going to be able to do that. The tension on the final drive belt may prevent you from being able to get the axle started back through the wheel bearings. My suggestion is to measure BOTH adjusters to see how they are adjusted. Both sides should be adjusted to the same length between the adjuster and it's lock nut. This is how you ensure that the rear wheel is properly aligned with the swingarm and frame of the motorcycle. Both adjusters on either side of the swingarm should be the same when the final drive belt tension is correct. The only other thing I can say is to make sure you mark the wheel spacers so that you don't get confused as to where they go when you go to put the rear wheel back under the bike. You'd be surprised at how many times I'm asked this question. I've been working on bike for years and I still mark them. Are you taking your girl to the "Wheels Through Time Motorcycle Museum"? Don't miss this, it's unbelievable. Last time I was there, the owner was doing burn-outs inside the museum on a 1936 Crocker. Unreal. That alone was worth the price of admission.
http://wheelsthroughtime.com/
Good Luck & Ride Safe.
Steve
Sep 09, 2011 | 2000 Harley Davidson FLSTF Fat boy
I accidentally put in the wrong language, I don't know how to get english back...thanks:)DeeDee
To change language or date/time in the future, yo should use the Setup menu,
  1. Setting up your camera
    • Attaching the strap
    • Loading the AA batteries
    • Turning on the camera
    • Setting the language and date/time
    • Storing pictures on an SD or SDHC Card
just in case if you need user manual in pdf format pls visit the link
below...
KODAK
EASYSHARE C195. Digital Camera.
Extended user guide
http://support.en.kodak.com/app/answers/detail/a_id/19314/selected/true
KODAK EASYSHARE C195 Digital Camera resources.kodak.com/support/pdf/en/manuals/.../C195_xUG_GLB_en.pdf
www.kodak.com .....
Aug 07, 2011 | Kodak C195 Digital Camera
I DON'T KNOW HOW TO OK I NEED THE AWNSER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You will not be able to find an answer if you do not ask a question or state a problem. Currently we know that you need an answer on how to do something but you don't state what your problem actually is. Please resubmit problem so that we might better assist you with a solution.
Also putting many exclamation points at the end of your statement does not assist in getting a solution any quicker. Thank you.
Jul 31, 2011 | Video Game Consoles & Games
I get vapor lock everyday in my 1992 buick grand margui v8 especially in the simmer here in las vegas. Whar do I do to fix it? What causes it please!
How would you know that you get vapor lock?
We don't live in the 1950 or 1960's any more
Explain what the drivability issues your having are
& what has been done to diagnose it
Jul 04, 2011 | Buick Rendezvous Cars & Trucks
Sony Handycam CCD-TRV68 Camcorder Logo
14 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
